Goal 350hp at the wheels
Like many other 350z owners my goal is to get 350 plus horse at the wheels. How do I do it and where to start. Plus haveing great track times also would be a plus if you know what im sayin.
I would just add a supercharger if I was looking for that kind of power.
Its kind of expensive but as we all know horsepower cost $$$.
I would say with a charger you could reach that goal or at least come darn close.
Just a thought.
Just a thought.
You can put all the NA mods you want on the car, and it'll cost a **** load of money and won't get you 350rwhp. Supercharging is the most cost-effective way to get that much power. The HKS supercharger is more expensive than some turbo kits so I wouldn't suggest it. Vortec superchargers can get the job done for relatively cheaper price.
If you dont plan on doing the install . Find a good shop first , talk to them and then decide what system to go with . Vortrech and ATI will get you close to 350whp out of the box [ATI will need extra's ] With a good tune it will get you more than 350whp . You'll be suprised once you get started.......your always looking for more hp.....I broke a piston looking for it. But Im still haven fun doing it . I think after I get the car back on the road , my quest for more hp will be surpressed till I get it all paid for this time
I never said that you can't get 350rwhp. I said getting 350rwhp NA is nearly impossible. 350rwhp FI is pretty easy actually, you'll need about $5,000 for eveything to get that much power.
I hope to be in the 300 plus NA range when im done with my Z. But im porting and polishing my heads, intake, and intake runner. Also i will be running 1mm larger valves. Last i already have all the mods listed. So the best way to get the hp is supercharging or turbo. I just screwed up on a cam install and bent some valves so i went the porting and polishing route. Im gonna be building the car back up this week.
If anyone is wondering i got the ferrea valve kit for about $1600.
The kits contains 1mm larger stainless steel intake and exhaust valves. Along with stronger springs, retainers, keepers, and shims. If you want a little more power have the shop doing the work put the valves in at a radius cut. Instead of the 3 to 5 angle stock seating.
Wish me luck Glen
Wish me luck Glen
Well now Its just a matter to choose between vortech, procharger, HKS, and Stillen for a super charger.
Fernadito how long does the install take on a greddy kit opposed to everything else out their?
And for some reason jimmity criket tells me to go with the rotrex, any suggestions
A car with a tilton flywheel will still pass you at low speeds. With 350 whp, you can't get a tilton street clutch so your next option would be to get an exedy clutch and flywheel. That and any form of forced induction would be pretty sick.
Also, the 350evo gear ratio would be really killer as well. Your car will feel a lot zippier with those little drivetrain mods, oh and might as well get a Quaife. Those differentials are indestructable!!!!!!!
Turbo's are harder on the drivetrain as well and will give you a lot of power to handle, maybe a supercharger would be better.
IM SURE ILL BE IN THE 300 RANGE. With all my dam bolt ons i would be near 280. I dont understand how you guys can make comments on something yet not have the job even done. The heads are one of the biggest parts of your engine if they flow better common sense wise it tells you it will gain alot more power. Logically with a good set of ported and polished heads and all the mods i have listed it will work better then to have the mods without the heads done. After all most of the mods run off your HEADS like headers for example!!!
The machine shop doing the job got 20 percent more flow out of my factory heads, but im sure ill gain a small amount of power lol. I find it strange how you guys get a hard on over a plenum and look at ported and polished heads as if its a dam grounding kit.
No offense to anyone im targeting Phoenix the know it all. Its funny because I IM him and he cant answer any of my questions. His only answer is to ask Doug at crawford bet yet he seems to know it all on here.
With a Supercharger mpg would be somewhere around the 16/17 oppossed to 19/20 stock with a turbo it would probably somewheres around 23/25 do i have the figures right?
hmmm...i read somewhere that stock internals are only good (read reliable) up to 350-400 flywheel horsepower. however, a lot of people on the board seem to have beat that bad rap. anyway, consider what you want to do with the car. if you street it, then just get a blower for the kick in the pants you are looking for - it will be the cheapest, easiest way to have fun. if you track the car, road race or drag, regularly you should consider upgrading the internals as you will push the car more often than not above its 'normal' limits.
-rich
-rich
Once you started doubting, it was when I cut you off... and did everything BUT block you. You IMed me for nights and nights and nights and night talking MUCHO LOCO!!! Seriously you are a bit over zealous and WAY over thinking things. Doug and I have shared many conversations about you...
One thing you need to learn, and I am MORE than willing to admit... Doug has over three decades under the hood of a car, to my five years... I have MUCH to learn.
Zmego1985... dude... Word of advice, don't **** talk the people that are here to help you. Otherwise you may not find a friendly opinion on the other end. You're a little hot-headed punk kid, and think you know more than you do. God bless I grew out of that stage long enough before I jumped into this car.
Bottom-line... those cams are NOT going to push you there. Just don't want you to be disappointed. Now get over yourself, and quit pissy that you screwed up an install.
