ARP Rod bolts out for the VQ35
Old Nov 15, 2004 | 06:12 PM
  #41
SR20DEN's Avatar
SR20DEN
That is mainly for the other style of rod bolts. In most cases the rod journal needs to be resized if new bolts are installed. But with this style of bolts I don't see why this step can't be skipped. The journal shape, positioning shouldn't change.
Old Jan 5, 2005 | 12:34 PM
  #42
Z350Lover's Avatar
Z350Lover
SR20DEN:
hows everything going now after the rod bolts? any updates?
cheers,
richie
Old Jan 22, 2005 | 03:13 PM
  #43
cupcar's Avatar
cupcar
What about the valve springs, I would worry about the need to change them before the trip to 7500 rpm
Old Jan 22, 2005 | 04:50 PM
  #44
tilleys99's Avatar
tilleys99
i purchased the ARPs and im revving to 7400 on the dyno.
Old Feb 4, 2005 | 07:43 AM
  #45
SR20DEN's Avatar
SR20DEN
There are people revving stock, heavier, VQ30 valvetrains higher than that. They have the same valvesprings we have.
Old Feb 5, 2005 | 12:29 AM
  #46
S12 driver's Avatar
S12 driver
How's the cryo'd rods working out? I heard that cryo treating the rods are really expensive and not really worth it, is it really the case?
Old Feb 13, 2005 | 11:52 AM
  #47
SR20DEN's Avatar
SR20DEN
The stock rods and ARP rod bolts are holding up just fine for over a week now. I have smacked the 7500rpm rev limiter dozens of times since I got my L-Spec ECU with no problems whatsoever. Right now I shift at about 7200 for powerband reasons but I hope to extend the power peak from 6250 to 7250 with alot more tweaks to make complete use of my new rev limiter.
Old Apr 22, 2005 | 09:09 AM
  #48
Nano's Avatar
Nano
how long/hard was the install? I have come to understand that everything on 350z is cramped, hard access and a pain in the *** to work on, lol.
SR20DEN, any updates? I have to thank you as I am proceeding same/similar route with my VQ. Real eye opener, made NA worthwhile for me.
trolls abound on the board, do not mind those.
Old Apr 22, 2005 | 10:11 AM
  #49
mojo powered's Avatar
mojo powered
this is really interesting and definitely something I'd consider doing.. can anyone chime in on how hard the install is.
Old Apr 22, 2005 | 11:49 AM
  #50
Go Speed Ricer's Avatar
Go Speed Ricer
To just change just the rod bolts can it be done under a lift without taking the engine out? Or is it too hard to access
Old Apr 23, 2005 | 10:07 AM
  #51
SR20DEN's Avatar
SR20DEN
It only takes a couple of hours to do in the Maxima. I can't say for sure on the 350Z because I don't remember what the K member looks like.
Old Apr 23, 2005 | 07:12 PM
  #52
Tex Willer's Avatar
Tex Willer
How's the maxima running? Have you tuned it past 6600 yet? What rpm are you producing those numbers at?
Old Apr 23, 2005 | 08:38 PM
  #53
SR20DEN's Avatar
SR20DEN
I havent had the car on the dyno since I got the Lspec ECU. My hp peak was at about 6250rpm.
Old Apr 25, 2005 | 06:20 AM
  #54
mojo powered
hey SR20DEN, what kind of cams are you using/planning on using to get the 7250 power peak if you don't mind me asking? Is it going to be custom grind?
will you be going to the maxima meet in Harrisburg? I guess it's a long stretch for you but hey, I'm thinking about going. I'm a little more than an hour away.
sales@czp
Sep 23, 2019 03:30 PM
pr_350z
Oct 1, 2015 05:03 PM
