stillin engine dampner?
Old Nov 2, 2004 | 08:26 PM
XBS's Avatar
XBS
Veteran
Default stillin engine dampner?
what do you guys think of this?
http://www.stillen.com/Sportscars_de...d=55283&page=1
Old Nov 3, 2004 | 04:25 AM
zillinois's Avatar
zillinois
I like it. A little cheaper here . .
http://www.performancenissanparts.co...oducts_id=1596
Old Nov 3, 2004 | 06:20 AM
moog's Avatar
moog
looks good...I have a Pro-1 damper =)
Old Nov 3, 2004 | 07:11 AM
mofoz's Avatar
mofoz
what does it do?
Old Nov 3, 2004 | 10:28 AM
Edogg218's Avatar
Edogg218
We should try and get a group buy from Jason if there hasn't already been one and people are interested...
Old Nov 3, 2004 | 11:21 AM
alininger2001's Avatar
alininger2001
Here's how I think it works and what it does. Basically your engine is mounted to your body on rubber bushings. This allows the engine a little movement. What the engine dampener does is connect the engine and the body in another point. Basically it causes the engine to move less when under torque loads. This wiil make your car feel la little better when shifting, especially in corners.
Old Nov 3, 2004 | 12:14 PM
jmckuhen's Avatar
jmckuhen
I would be down for a group buy
Old Nov 3, 2004 | 12:35 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I'm in for a GB.
Old Nov 3, 2004 | 12:56 PM
Sins4u33's Avatar
Sins4u33
eh **** it im in!
Ben
Old Nov 3, 2004 | 02:12 PM
XBS's Avatar
XBS
Veteran
me too lets do it does anyone know where it mounts? or have a pic of it mounted?
Old Nov 3, 2004 | 02:38 PM
nismo33's Avatar
nismo33
BoNe SToCK BaSe
i would be interested in a group buy on this as well
Old Nov 3, 2004 | 03:39 PM
alininger2001
It probably mounts like this one, adding this would probably be the equivalent of getting polyurethane motor mounts.
alininger2001
http://www.performancenissanparts.co...ge.php?pID=446
Old Nov 3, 2004 | 03:40 PM
alininger2001
That is the 5zigen one, but that is probably how the stillen one mounts.
Old Nov 3, 2004 | 06:43 PM
ypwpat's Avatar
ypwpat
will this still transfer the vibration to the cabin?
Old Nov 4, 2004 | 02:08 AM
Edogg218's Avatar
Edogg218
It can't be as bad as the solid mounts that I had in my Spec V...maybe someone can jump in?
I'll ask Jason and some others if a group buy is possible today, and post all of the details, if there are any
Old Nov 4, 2004 | 02:34 AM
zillinois's Avatar
zillinois
You will get some increased cabin vibration. Its very diffuse though. You can't tell where its coming from so you get used to it very quickly. Now I can't even tell if there's more noise than before or not, even if I go for a ride in someone else's Z.
Old Nov 4, 2004 | 03:54 AM
alininger2001
Will this help prevent wheel hop?
Old Nov 4, 2004 | 04:26 AM
zillinois's Avatar
zillinois
It made a noticeable reduction in wheel hop.
Old Nov 4, 2004 | 11:26 AM
alininger2001
I'm in, if it can help wheel hop my times will go down.
