Cusco LSD install Base model info
Old Nov 8, 2004 | 12:52 AM
Poizon's Avatar
Poizon
Default Cusco LSD install Base model info
If you need info on additional parts and part numbers you will need let me know. Dan
Old Nov 8, 2004 | 01:13 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Not 100% on the Cusco but with the NISMO you need to change the final drive gear to the 6MT...
Nismo LSD is complete except for the ring and pinion of the 6mt
Old Nov 8, 2004 | 10:25 AM
Gsedan35's Avatar
Gsedan35
Default Re: Cusco LSD install Base model info
I'll give you a pin point answer, since I think you have the RS Cusco all that I ask in return is that you do a review once you get some miles on diff. And I mean that, please do a review for us.
You will have to buy the following (yes these things do come with the Nismo LSD inside the box).
stub axles $148 each, part numbers 38220-AR011 and 38220-AR010.
2 Oil Seals $6.50 each ment for a stock limited slip equipped diff part number 38342-P9010
And 2 Differential Bearing assemblies $48.00 each, also ment for a limited slip equipped diff part number 38440-0C000
Old Nov 8, 2004 | 10:49 AM
Poizon's Avatar
Poizon
Jason if I use a bearing puller can I use the same bearings that came out I only have a few thousand miles on the car. Are they the same bearing and or part #. The person doing the install can get bearings off without any damage. Thanks dan! And yes I will give a review.
Old Nov 8, 2004 | 11:47 AM
Jason@Performance
Performance Nissan
148? thats list price...
take 20% off that price and you get them from me...
Old Nov 8, 2004 | 04:29 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yes you can reuse the bearings - I did when installing my LSD
Old Nov 8, 2004 | 06:19 PM
jtanaka215's Avatar
jtanaka215
Jason,
I just got the Nismo LSD from you. I need also a ring and pinion to do the install? Please enlighten me.
Old Nov 8, 2004 | 09:57 PM
Gsedan35's Avatar
Gsedan35
Originally posted by jtanaka215
Jason,
NO, you do NOT have a automatic transmission car. Your sig says your have a base Z, meaning a 6-sp, you don't need to buy a right and pinion gear set. Your installer will simply use the one your already have.
Old Nov 8, 2004 | 10:21 PM
nitrous350's Avatar
nitrous350
Hey guys
i had a 2003 AT i try to change my final drive
any one can reconman.. me a parts
Old Nov 8, 2004 | 10:33 PM
jtanaka215's Avatar
jtanaka215
Thanks Gsedan.
I just had one more question. Is the Nismo LSD a lot different than open diff cars? I know power is being put to both tires, but even with my open diff I would get power to both tires. I know this from what I was burning some rubber.
Old Nov 9, 2004 | 04:47 AM
SvR350z's Avatar
SvR350z
Ok so Im a newb but what exactly does this nismo deal do?
I have a base model and maybe i need this?
Enlighten me jason
Tochigi_236
Sep 27, 2015 03:40 PM
