Best Rear Diff Fluid?
Old Nov 9, 2004 | 06:56 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default Best Rear Diff Fluid?
Since the 350Evo ring and pinion has been in now for a few thousand miles I want to replace the rear diff fluid with some quality stuff...what are your recommendations?
I have read a few forums mentioning Redline, Schaefers and Royal Purple interchangeably as all being good brands. My own non scientific use of this stuff over the years tells me that what works well in one application does not always work well in another.
So what have you guys used in your Z's that you have been happy/unhappy with? What was the net result of changing the fluid performance wise for you (was noise reduced, increased, etc)
Thanks in advance!
Adam
Old Nov 9, 2004 | 07:18 PM
alininger2001's Avatar
alininger2001
I used redline and it shifts al ittl better when cold, but other than that, no noticable difference. Does Amsoil make gear oil?
Old Nov 9, 2004 | 07:39 PM
350Zteve's Avatar
350Zteve
Mobil 1. The best in my book
Old Nov 9, 2004 | 07:52 PM
GY-Z's Avatar
GY-Z
Motul.
Old Nov 9, 2004 | 07:56 PM
03Z33's Avatar
03Z33
It is not recommended to use synthetic gear oils in clutch pack LSD's such as Nismo, KAAZ, Cusco. It may even cause your LSD to fail, or not engage properly.
I use the KAAZ fluid exclusively since it has the right additives and seems to quiet down the clunking. I change oil after every event or 3,000 miles. It's not cheap though.
Old Nov 9, 2004 | 08:01 PM
maximumsportZ's Avatar
maximumsportZ
Sup Adam,
I use AMSOIL Series 2000 Synthetic 75W-90 Gear Lube in both my diff. and tranny. This fluid meets both diff. and tranny API MT-1 & GL requirements.
For more information on this fulid check out: http://www.amsoil.com/products/tgr.htm
Old Nov 9, 2004 | 08:03 PM
GY-Z's Avatar
GY-Z
oh, i never know that, thanks for point out.
but i guess its not applied on the stock vicious differential?
Old Nov 9, 2004 | 09:23 PM
lovetoclown's Avatar
lovetoclown
I run a royal purple gear oil and a friction modifier. Works good in my book. rear grabs very well and is quieter.
Old Nov 10, 2004 | 08:57 AM
stiv's Avatar
stiv
Redline (lightweight) shockproof gear oil. You can run it in your tranny and your differential...
Old Nov 10, 2004 | 12:18 PM
arizzee's Avatar
arizzee
Recently switched to Amsoil Series 2000 in both tranny and diff. Tranny is noticeably quieter and I swear I'm getting more torque to the wheels as I can break them loose much easier.
Old Nov 10, 2004 | 01:10 PM
maserom's Avatar
maserom
Royal Purple Kicks Butt!!
Old Nov 10, 2004 | 03:48 PM
G3po's Avatar
G3po
Default Diff oil
I run RP 57W90 Max in the 6MT, works fine.
Have run the same other "clutch type diffs" without issue.
Intend to run the same in my new Cusco RS.
Friction modifiers are not necessary with RP max.
Old Nov 10, 2004 | 04:49 PM
Nano's Avatar
Nano
I use Royal Purple Max Gear in both tranny and diff...
yeah, kick ***
Old Nov 11, 2004 | 07:07 AM
Phatmitzu's Avatar
Phatmitzu
Originally posted by GY-Z
Motul.
Same here.
Old Nov 11, 2004 | 07:12 AM
Z-Z's Avatar
Z-Z
I just switched to Mobil 1 synthetic in my 350Z stock diff (and also in the wife's BMW M roadster's diff). It's the easiest to find. I've been happy with it in both cars.
