Mossy Performance/FastShift Short Shifter Now Available!!!
Old Nov 11, 2004 | 11:01 PM
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
I talked to Steve at Mossy today. The rattleing issue has been solved . I will most likely get my hands on one this weekend at the Show .
Bat™
Old Nov 12, 2004 | 08:43 AM
MIAPLAYA's Avatar
MIAPLAYA
Bat™
Absolutely correct...
Old Nov 12, 2004 | 09:13 AM
jmark's Avatar
jmark
I have the Rogue short shifter. Has anyone here compared the two? I personally like the Rogue but feel it is a little notchy.
Old Nov 12, 2004 | 11:26 AM
G3po's Avatar
G3po
Default rattle
Do you note any audible rattle witou you Rouge. I get a little with my Rouge at >5k rpm, rapid engine braking in 2nd gear. I wa thinking about tryng a weighted ****, shoudl help with the nothcy feeling as well.
Old Nov 13, 2004 | 03:00 AM
solja's Avatar
solja
"bow wow wow yippyo yippya"
yeah please, pix would be better to see the sets "long/mid/short"
btw, does it come with the chrome ring, that one around the shifter?
Old Nov 13, 2004 | 05:57 PM
uro279's Avatar
uro279
So does the shifter change the throw by changing the shifter height, or is the throw already shortened regardless of height?
Old Nov 14, 2004 | 04:50 AM
MIAPLAYA's Avatar
MIAPLAYA
The shifter changes the throw by adjusting the height. BTW the fix to resolve the rattling was very simple. The stock Nissan Shift cup was the problem all along. Because of the way it sites in the housing it allows movement between it and the mounting area. This caused the assembly to vibrate. Fast Shift resolved it by using some rubber o rings on the shift cup to stop the vibration. Their design is vibration free.
Old Nov 14, 2004 | 05:26 AM
uro279's Avatar
uro279
Any pics coming up soon?
Old Nov 14, 2004 | 06:04 AM
MIAPLAYA's Avatar
MIAPLAYA
Yeah I still have to upload them. Sorry busy weekend.
Old Nov 18, 2004 | 08:07 PM
company man's Avatar
company man
Default 17-4 stainless steel
The shifter adjusts both above and below the fulcrum. When you release the locking collar from the highest position, the shifter handle drops down, lowering the shift **** at the same time lengthening the shifter below the fulcrum, therefore shortening the throw both above and below. The shifter arm is a solid piece of 17-4 stainless steel that is hardened to 40 Rockwell along with some of the important internals. Basically stronger than the same material in a forged steel crankshaft. Your gonna break your arm before you can even bend this baby.
Nissan UD 2600 Turbo
if you can't beat'em, crush'em
Old Nov 19, 2004 | 10:52 AM
G3po's Avatar
G3po
Default Re: 17-4 stainless steel
Pics please....
Old Nov 19, 2004 | 01:28 PM
MIAPLAYA's Avatar
MIAPLAYA
Default Re: Re: 17-4 stainless steel
Originally posted by G3po
Pics please....
Will be up tonight..
Old Nov 19, 2004 | 03:26 PM
ReavTek's Avatar
ReavTek
I have a B&M Short Shifter.. It is way too notchy and must be slammed into gear. Will your shifter at the stock setting be just as fluid as stock?
Old Nov 19, 2004 | 05:39 PM
company man
Default as fluid as stock?
This is an adjustable shifter. There are four positions of adjustment.
1. Upper position, 20% longer than stock, very fluid, your girl will love it.
2. Down one notch, Stock position, the same throw length and feeling as stock.
3. Down another notch, first short position, 20% shorter than stock.
4. Down to bottom notch, second short position, 40% shorter than stock.
This can all be done while sitting in the drivers seat with your right hand on the shifter **** and your left hand around the dust boot pulling on the release ring. No different than changing the angle of your steering wheel.
Old Nov 19, 2004 | 09:58 PM
ReavTek's Avatar
ReavTek
Default Re: as fluid as stock?
Any special deal for 350z forum members? How about a group buy, PM me if you can get us good pricing.
Old Nov 19, 2004 | 10:42 PM
spazpilot's Avatar
spazpilot
It really did not seem to me that its a short throw shifter it looks like it just adjusts the top to make it look like one. the throw seem the same to me at all levels on that video. just my .02
Old Nov 19, 2004 | 10:50 PM
JimRHIT's Avatar
JimRHIT
changing the setting was definitely noticeable. Maybe the vid did not illustrate it well, but the feeling is surely not negligeable. I like the shifter as is, otherwise I would be getting this one.
Old Nov 20, 2004 | 08:24 AM
  #38
company man
Default Patent Pending
The shifter adjusts both above and below the fulcrum. Patent Pending
Old Nov 20, 2004 | 09:28 PM
  #39
MIAPLAYA's Avatar
MIAPLAYA
Default Re: Patent Pending
No pics yet sorry guys. Waiting to get them emailed to me..
Old Nov 21, 2004 | 09:00 AM
  #40
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
It is an adjustable HEIGHT shifter... Not a short throw shifter like the B&M / Rogue...
Here is my review...
https://my350z.com/forum/showthread....threadid=99723
here are my pix...
I have the latest revised version installed and reviewed...
