DIY plenum porting
Old May 25, 2008 | 07:47 PM
  #441
03VQ35DETT's Avatar
03VQ35DETT
Originally Posted by Hydrazine
Anodize would be trick.
I can't recall ever seeing that.
i never thought about that, i know some people through my work that do anodizing. i really need that 600 bucks from the government so i can get a couple lowers to mess with. i want to port match and hone a lower and the y manifold to the heads, port match the heads, get one of your 5/16 iso thermal spacers and slap it all together with my upper and see what happens heh
Old May 26, 2008 | 01:13 PM
  #442
sebg350z's Avatar
sebg350z
whats a good brand for a plenum space for a 350z and if it helps or not?
Old May 26, 2008 | 07:19 PM
  #443
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
That's easy.
Just click the link in my signature below and look around the website for a lot of information on the subject.
PM me if you have any questions.
Tony
Old Jun 29, 2008 | 04:10 PM
  #444
mw9's Avatar
mw9
nice work boys. Does anyone have any plenums upper/lower for sale
Old Sep 9, 2008 | 09:55 AM
  #445
first350's Avatar
first350
FWIW - I took my plenum apart last night b/c the top exterior portion had some small hairline cracks developed and small amounts of oil was seeping out...
the epoxy is holding up perfectly - looks like the cracks on the exterior are just due to thermal cycles and the difference from the paint/plenum/epoxy...not sure how the oil is getting through - I wonder if the expoy is porous enough to allow the oil to seep through??
didn't get a chance to take any pics last night...but here's a pic of what it looked like before:
here's it unfinished...you can see the epoxied areas.
finished version
installed
Old Sep 18, 2008 | 10:50 AM
  #446
bikinilust's Avatar
bikinilust
maybe try getting your upper plenum powder coated. That should create an impermeable coating, no?
Old Sep 18, 2008 | 05:37 PM
  #447
JSpec350GT's Avatar
JSpec350GT
Originally Posted by 03VQ35DETT
i have a couple more pics from tonight, i did a little grinding and sandblasting of the entire inside and sandblasted the welds on the outside. i will most likely blast the whole outside too before i powdercoat it.
i think its about time to start shopping for some lower plenums, anyone have a revup lower that they are willing to part with
I'm doing my also but I'm going to take them all out.
Have you notice any performance increase by doing this? How's butt dyno say?
Old Sep 18, 2008 | 06:30 PM
  #448
Cide's Avatar
Cide
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
i started mine a couple of weeks ago. I'm taking down all the stubs but i get the manifold back tomorrow from welding ill have pics as soon as i get it.. and i also have a lower that im going to play around with.
Old Sep 19, 2008 | 06:57 AM
  #449
bikinilust's Avatar
bikinilust
wouldnt it have been better to fill in the holes from the top side prior to removing the legs?
Old Sep 19, 2008 | 08:11 AM
  #450
Cide's Avatar
Cide
well i am getting new aluminum welded in those holes and then i'll use the jb weld after i grind down everything nice and smooth to get everything looking the way i want it.
Old Sep 19, 2008 | 01:12 PM
  #451
bikinilust's Avatar
bikinilust
nice... cant wait to see the outcome
Old Oct 4, 2008 | 04:05 PM
  #452
Cide's Avatar
Cide
got the manifold back and grinded down the welds. I did what i cold with just sanding cuz the guy that welded it tried to fill in the gap after he had welded a round piece of aluminum, but didnt do suck a good job on that part. nothing a lil J&b weld cant fix.
Inside is better. dont know if i want to j&b weld the lil holes or just leave them though.
Old Oct 5, 2008 | 10:26 AM
  #453
Quamen's Avatar
Quamen
Wonderful job!
I did the same thing but left one bolt in the center. I think this has been one of the best intake mods I have done on my SC'd Z. I don't seem to have the torque/horsepower drop off that many seem to experience on boosted Z's.
Old Oct 5, 2008 | 05:13 PM
  #454
Cide's Avatar
Cide
Fresh J&B Weld. Now i have to wait till it cures and then i can sand it which will be later on tonight.
Old Oct 6, 2008 | 11:17 AM
  #455
VO...'s Avatar
VO...
Administrator
Originally Posted by Wired 24/7
I would rather see the angled cut approach and then if you want to increase volume, try a spacer. Hell you can even use the gasket trick where you stack like 20 gaskets to make a ghetto spacer.
Old Oct 7, 2008 | 11:19 AM
  #456
Cide's Avatar
Cide
J&B weld sanded on the front and ready for paint.
inside completely sanded with 320 grit
freshly painted
after 30 min of drying with the wrinkle setting in
tomorrow i start on the lower one
Old Oct 7, 2008 | 11:20 AM
  #457
Cide's Avatar
Cide
What do u guys think?
Old Oct 7, 2008 | 06:09 PM
  #458
03VQ35DETT's Avatar
03VQ35DETT
looking good man, i like the finish on the paint. i still have my modded upper but i just got rid of my z so i don't really have any reason to mess with all of that anymore. i wish i would have gotten to do more with it all
Old Oct 7, 2008 | 07:46 PM
  #459
bikinilust's Avatar
bikinilust
let us know if theres any performance difference via the butt-dyno
Old Oct 9, 2008 | 06:54 PM
  #460
Cide's Avatar
Cide
Its lower is done and going on the car tomorrow
Gotta Represent..lol
