DIY plenum porting
Old Oct 10, 2008 | 05:00 PM
  #461
bikinilust's Avatar
bikinilust
what exectly did you do to the lower? I see that you smoothed everything out and removed castings and text. But did you lower the front runners?
Old Oct 11, 2008 | 10:29 AM
  #462
Cide's Avatar
Cide
i lowered the all of them in the same slope pattern that the top plenum has.
Old Oct 13, 2008 | 11:05 AM
  #463
Cide's Avatar
Cide
U cant really tell from the pics but i took off a good amount from the front runner but i also lowered the others. i thought i'd try something diff so i lowered them in a downward slope like the top plenum does to get a better even flow all round..... Finaly got it on the other day took me prety much the whole day cuz i decided since i was in there i might as well get creative.. so i painted my throttle body to match the manifold and also replaced my valve cover gaskets and painted the covers red... right after i finished i cleaned up, made sure everything ran good, and took it on a 1 hour drive at about 80-85 mph and everything held up awesome... gains via dyno butt r noticable but it could just be in my head.. my g.f did notice it sounds a tad meaner.. and im getting about 1 mpg more than b4 so thats always good.
Old Nov 25, 2008 | 04:43 PM
  #464
Cide's Avatar
Cide
hey anyone ever tried porting the rev up lower plenum?
Old Mar 3, 2009 | 09:16 AM
  #465
Jeff92se's Avatar
Jeff92se
Old Sep 30, 2009 | 12:27 PM
  #466
SexyRob's Avatar
SexyRob
I'll try to keep this alive, would be great if some of the people who inspired me could come back and give us all a check up...
Casting Surface
Big casting flaw
Grinded off the top of the front runners
Before I started grinding
After around 30 mins
more than an hour of grinding at 80 grit
another 30 minutes at 120 grit
attempting to grind around the curve
Old Sep 30, 2009 | 05:31 PM
  #467
eltness350's Avatar
eltness350
The Untouchable
lookin good!
Old Oct 3, 2009 | 12:09 PM
  #468
Cide's Avatar
Cide
good job man i can tell u have better tools for the job than i did. should come out good.
Old Oct 22, 2009 | 12:25 PM
  #469
LSX-PWR's Avatar
LSX-PWR
I gasket matched the runners and ported the rest or the intake. I'm thinking of selling it though, reason being im putting a LSX in my Z.
Old Nov 25, 2009 | 07:33 AM
  #470
SexyRob's Avatar
SexyRob
Finished Lower Runners
Old Nov 27, 2009 | 10:22 AM
  #471
bikinilust's Avatar
bikinilust
what kind of tools did you use?
Air grinder w/sanding pads n sanding drums?
Old Nov 27, 2009 | 11:54 AM
  #472
SexyRob's Avatar
SexyRob
combination of: a sanding porting/polishing kit from summit racing, a surface prep kit for air tools, sandpaper of various grits, a dremel with flex line and a rotozip, and a couple ingenious ways of putting them all together.
Old Nov 27, 2009 | 01:06 PM
  #473
bikinilust's Avatar
bikinilust
whats the surface prep kit.
I pretty much have all of those items minus the summit kit, which ive seen for a very reasonable price.
Any tips?
And how does the butt-dyno feel after all these mods are said n done?
thanks
Old Nov 27, 2009 | 02:31 PM
  #474
SexyRob's Avatar
SexyRob
got the surface prep kits at lowes/homedepot near the air compressor equip
this is still a work in progress. I have a dyno day scheduled on the 13th of December where I hope to have a before and after reading. I will compare the stock Throttle body>Upper Plenum>Lower Plenum>Runners to my modified versions.
Old Nov 27, 2009 | 05:48 PM
  #475
bikinilust's Avatar
bikinilust
what was your method for bringing down the tops of the front 2 runners consistantly?
Which tools did you use?
Old Nov 27, 2009 | 07:02 PM
  #476
SexyRob's Avatar
SexyRob
put the surface prep kit on the rotozip and used the roughest pad for like 30 minutes
Old Nov 28, 2009 | 08:56 AM
  #477
bikinilust's Avatar
bikinilust
you used a measuring caliper before and after, right?
How much did you bring down the tops of the 2 front runners?
I have yet to do that portion of the project due to not knowing how much to bring it down.
Old Nov 28, 2009 | 09:03 AM
  #478
bikinilust's Avatar
bikinilust
which kit did you go with?
http://www.summitracing.com/search/?...porting&page=1
Also, what was the final grit that you used? Im thinking to leave the whole thing a little rough, like maybe 120 grit....
Old Nov 28, 2009 | 09:22 AM
  #479
SexyRob's Avatar
SexyRob
think its this one, http://www.summitracing.com/parts/SAI-260006/
didn't really check to see how much to bring it down, I just did what looked right. I was conservative in my decision since I figured a little was better than nothing but too much could be very bad.
I'm not done yet but I think I will finish off with 150 or 220 by hand.
Old Nov 28, 2009 | 02:55 PM
  #480
bikinilust's Avatar
bikinilust
how did you do on the runners of the lower plenum?
I think i tried it like a year ago, n from what i remember the turn made it difficult.
I believe flapper style sanding bits worked best on those turns.
