DIY plenum porting
Old May 9, 2011 | 07:42 AM
  #601
pfregeolle's Avatar
pfregeolle
I guess by bolting only the two hole on the front and rear of the lower plenum....should be interesting though. I suggest a lot of gasket maker haha
Old May 9, 2011 | 10:26 AM
  #602
bikinilust's Avatar
bikinilust
I never said it was welded shut.
It is still 3 pieces [upper, plenum spacer, and lower]
It just appears that it is one piece because everything was ground, sanded, and smoothed together.
Old May 9, 2011 | 10:30 AM
  #603
bikinilust's Avatar
bikinilust
Originally Posted by pfregeolle
did you remove the posts on the inside or are they still there?
Posts inside are still there
I will also gasket match the lower collector and the lower plenum, and maybe get rid of all the cast marks.
As for the MREV2 mod, prob wont do that till im ready to get tuned.
Old May 10, 2011 | 08:21 AM
  #604
pfregeolle's Avatar
pfregeolle
Here's a quick sounds clip of the exhaust, and you can somewhat hear the intake sound during the shot where I'm appoaching the video camera....
http://www.youtube.com/watch?v=MSd-0mMzRow
Old May 10, 2011 | 10:35 AM
  #605
bikinilust's Avatar
bikinilust
nice!
By the way, how much does your flywheel weigh?
Seems like your engine revs pretty freely.
If my ears are correct, your intake has a hollowed out sound.... am i even close?
Old May 10, 2011 | 11:14 AM
  #606
pfregeolle's Avatar
pfregeolle
According to Carbonetic's webpage, the street verison, which is 1300kg pressure plate, flywheel/clutch combo weighs in at the same amount as stock. I have the 1600kg pressure plate, so I'm not sure if it weighs a little less. I would definitely assume it does. I couldn't find mine on the chart listed on Carbonetic's site though I know it was pretty light when I took it out of the box! Had Nissan install it when I got my engine replaced under the TSB
As far as the intake, it's a short ram design. It's the JDM Trust GReddy Intake system with the little mushroom filter that everyone is always bitxhing about. But I like it, and it'd different. Looks like this (but I have the blue filter):
Old May 10, 2011 | 11:17 AM
  #607
pfregeolle's Avatar
pfregeolle
P.S. You can hear the clutch like crazy at the end of the video, where I'm turning around to pull up to the camera.
Old May 10, 2011 | 01:11 PM
  #608
bikinilust's Avatar
bikinilust
In your opinion, is the clutch chatter worth the benefit of the lightened flywheel?
Old May 10, 2011 | 01:12 PM
  #609
bikinilust's Avatar
bikinilust
as for the sound of your intake sounding HALLOWED OUT, is that from the intake tube or the modifications you did to the intake manifold?
Old May 10, 2011 | 01:26 PM
  #610
Road Warrior's Avatar
Road Warrior
Originally Posted by SexyRob
still in the process of getting my before and after dynos posted... but here are some pics to feed the masses.
you are the picasso of porting...beautiful workmanship. really wish you would have done a before and after dyno.
keep this thread alive....great work to all
Old May 10, 2011 | 07:23 PM
  #611
pfregeolle's Avatar
pfregeolle
I honestly don't really mind it. There are times when I'm driving, say in 4th or 5th gear, and the RPMs are really low...if I try to give it too much gas the transmission gets REALLY loud and kind of vibrates the whole car until I get to an RPM where the gearbox is happier. But I kind of like it honestly. It definitely took some getting used to before I was ok with it though.
As for that hallowed out sound, I would imagine it comes from the plenum and manifold. I had installed that intake before I did the whole plenum set up and the only real difference I noticed was a bit more of a growl, and I could hear that weird whistling sound which comes from the throttle body on the VQ when you put an intake on it. If any of you guys have an aftermarket intake, I'm sure you know what I'm talking about. As far as I know, everyone experiences that weird whistle. But yeah, I don't really notice much of a hallowed out sound, it's possible it could just be the video, or maybe you just hear it differently than I do.
Old Jun 23, 2011 | 06:59 PM
  #612
LoSt's Avatar
LoSt
So I conned a co-worker, I mean a friend with a 350z asked me to take a crack at his manifold. After looking at it a little longer, I think the airflow around the 2 inputs that are closest to the outside edge could be improved. So I took this one a little bit further, in this picture it's the top left and bottom right portions I'm referring to:
I followed the flow of the casting a little better:
Here's the same area originally:
This is the other one I notched out:
Originally:
Original:
Thoughts? It's not installed yet, wondering if I should take the second area down a bit more.
Old Jun 24, 2011 | 08:09 PM
  #613
Cide's Avatar
Cide
I also shaved those down... just make sure you got the transition as smooth as possible.. you dont want to put it on and then beat yourself up weather you should have taken off that lil extra.
Old Jul 6, 2011 | 05:54 PM
  #614
raininotdead's Avatar
raininotdead
Awesome work!
Old Jul 6, 2011 | 07:48 PM
  #615
LoSt's Avatar
LoSt
I did notch it in a little more, my co-worker was happy with it. Now I want to take mine off and make those little changes! He did leave me his old plenum, so I could just port that one and swap it out.
Old Jul 10, 2011 | 03:14 PM
  #616
Cide's Avatar
Cide
Gotta love having extra parts to fool around with.
Old Jul 18, 2011 | 07:53 PM
  #617
BoomerZ33's Avatar
BoomerZ33
nice job sexy rob. i've always thought about doing this.
Old Jul 19, 2011 | 04:30 AM
  #618
pfregeolle's Avatar
pfregeolle
I feel like I should do something useful now with my oem revup plenum, upper manifold and lower manifold....
The whole setup is just sitting in my basement haha, I could probably smooth and polish the lower manifold and sell it on here...
Old Jul 20, 2011 | 03:28 PM
  #619
AntKneeGrod's Avatar
AntKneeGrod
nice, i just bought a sand blaster. this is definitely a near future mod
Old Jul 20, 2011 | 03:30 PM
  #620
mattleegee's Avatar
mattleegee
there is a plenum top on ebay for $30 right now.... practice?
