DIY: Ram pipe
Old Jun 20, 2007 | 05:36 AM
ickysz's Avatar
ickysz
Default DIY: Ram pipe
In the next couple of days I will be constructing a Ram pipe(with pictures) behind my grill w/ a 90 degree bend going towards my Injen intake (That I'll be getting in the mail soon), I'm getting this idea from someone who posted a DIY before, making one out of a garbage can, well I've decided to construct it out of pipe, I will be sizing it,cutting it etc... Hopefully this "mod" does improve cold air flow direction, we'll see.
Be looking for it!
Old Jun 20, 2007 | 12:38 PM
gothchick's Avatar
gothchick
Awesome. Can't wait. The ultimate would be the cool air draw of a cold air intake, with the lowered air resistance of a short ram...
Old Jun 27, 2007 | 02:03 PM
moforose3's Avatar
moforose3
Nice, Ive been thinking of doing this. Come on and do it already!
Old Jun 28, 2007 | 06:52 AM
sixsigmalarry's Avatar
sixsigmalarry
Smile hmmmmm....
I'm looking for it....
Be looking for it!
Old Jul 23, 2007 | 10:14 AM
sixsigmalarry
Still looking for it.....
Old Jul 24, 2007 | 05:04 AM
FORZWIN's Avatar
FORZWIN
You mean like this:
http://cgi.ebay.com/ebaymotors/JDM-N...QQcmdZViewItem
I run that in conjunction with a drop in filter for the stock airbox and a carbon fiber intake tube. Very clean, works well no problems.
Old Jul 24, 2007 | 05:17 AM
jtabraham's Avatar
jtabraham
1 month and no DIY?
What pipe material do you plan on using? What ID and OD? How many bends? How long will the tubing be. Will the the diameter stay constant throughout the piping? Do you plan on using any other cross-sectional shapes in conjunction with your round pipe?
Old Aug 10, 2007 | 06:52 AM
gothchick's Avatar
gothchick
Free bump~
Old Aug 15, 2007 | 01:13 PM
Tackett's Avatar
Tackett
...why is this in the DIY section...if there is no DIY in here at all. This thread is useless.
Old Jan 3, 2008 | 11:26 AM
robertsowka's Avatar
robertsowka
haha, this probably is the easiest diy mod out there! absolutely no gains though unfortunately... WHERE IS THE WRITE UP?
Old Jan 3, 2008 | 11:50 AM
Mazinger Z's Avatar
Mazinger Z
I'm going to make a DIY for a flux capacitator, please look for it in the coming years.
Old Apr 18, 2008 | 01:43 AM
Chad68's Avatar
Chad68
No pics LOL so sad.
I just installed my homemade intake ducting tube today. It's already on my car so no pics either LOL. I can post some this weekend though but since it's already mounted ain't a whole lot to see.
What I did was so simple. Takes about 25 minutes start to finish to make and install it.
I bought a non carbon intake duct but have been trying to decide if i want to hack up the bumper or not, so for now I did this mod instead to help get some cooler fresher air to my PC'er. If I do decide to install the intake duct, this same tubing will run off the back of the duct to in front of the filter
All I did was go to Napa Auto parts and pick up a 2" aluminum heat exchanger tube, which was like $3.80 with tax. The tubing is about 10" fully compressed and stretches to about 1.5" feet, which is long enough to go from behind the upper drivers side of the grill opening to the filter. It's like an accordian type tube, like the arms on the Robot from the tv show "Lost in Space" Danger danger Will Robinson.
I spray painted the lower 6" of the tube (inside and out) that goes behind the grill black, so it's invisable behind the grill. I left all the rest of it the natural alumnium color (part that will come out next to the headlight and into the factory inatke hole/opening).
The ghetto diagram I made shows how you would attach the tube to the plastic bracket I made. I just had some 3/16" black plastic laying around and used that.
The green shadded area is where double sided foam tape goes. That whole green area gets attched/stuck to the bottom and back side of the actual metal bumper on the car. Make sure you wipe off any dirt so it sticks good. The tab with the two circles when installed, will be towards the drivers side, just how it is in the diagram. That tab with two circles is where you bolt the black end of the tubing to.
Note. You do not need to remove the bumper and if you have a cooling plate, like I do, you don't need to remove that either to attach it. It might make it easier to remove the cooling plate, but I'm fat and didn't need to go thru the hood latch opening to stick it on the bumper. Just snake the tube with the bracket, foam tape already attached to it (peel the backing strips off the tape before you snake it thru), thru the opening at the bumper and headlight area, down behind the grill.
The 2 small circles on the pics is where I drilled 2 holes and used nuts, bolts and flat washers to attached the tube to the bracket.
You can secure the other end of the tube to the intake opening how ever you want. I just used one of those tiny black paper clip things and then took off the visable arm. Wood screw would work too.
Attached Thumbnails DIY: Ram pipe-duct.jpg
Old Jul 4, 2008 | 09:28 PM
Chad68's Avatar
Chad68
Heres a pic of the alumimium tubing I used.
Attached Thumbnails DIY: Ram pipe-5.jpg   DIY: Ram pipe-6.jpg
Old Jul 3, 2010 | 12:40 AM
KingBaby's Avatar
KingBaby
Hardest Setting
bump I'm in the process of doing this myself yet with vacuum tubing I sized everything already just need to remove my bumper tomorrow to fit it in...
I'm sure this doesn't provide any noticable gains at all, but let's think about this
isn't it better to funnel air from point A to B which this mod does rather than leaving it up to the air to find it's way to the airbox which is the stock setup?
my350z can you experts chime in...thanks tomorrow I'll update with pics...
Old Jul 3, 2010 | 10:05 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Default Plain Ole vacuum tubing...
So in my boredom I wanted to kinda improve upon the stock setup...
knowing that the stock airboxes are a great setup on the HR motors along with K&N filters or the HKS dry filters I felt getting more air to them is just stepping it up...
therefore the following...
TOOLS
2 1/2 inch vacuum tubing or tubing of your choosing...
Once you figure that out remove bumper then fit the tubing in the path that the air would normal try to follow...
Pics...
Full front
Right
Left
this is very straight forward...
feedback welcomed...
Old Jul 4, 2010 | 06:44 AM
G4nismo's Avatar
G4nismo
i mean from what i heard, air finds its way to the scoop pretty well. Air comes in and up the front bumper, over to the scoop and rammed in sorda say. I guess the hood kinda acts as a shield to allow air to pass by but dunno how much more effective those aluminum shrouds are. Whereas if you have a tube setup like you displayed, the air that is sucked in is only limited to the diameter/volume of the tube and my guess is its not going to create much of a ram effect. I see the normal setup (stock) working better b/c its drawing in sufficiently more amount of air, then compressed due to the smaller space up top, and accelerated it into the scoop.
Old Jul 4, 2010 | 12:09 PM
KingBaby's Avatar
KingBaby
Hardest Setting
...kinda true, and I was trying to just improve air flow. Therefore I started the tube at the point the where the air path gets to 2 1/2 wide this is where my tube starts..
picture above is me cutting away the excess tubing...
I should of tooking more pics but on the passenger side there are some wires in the way and these tubes I would like to say keeps air on it's path. The driver's side aswell has a metal plate in the way...I highly doubt this affects anything, but I bent it out the way allowing the tube to sit in there perfectly.
I wish I had some more tools and time to measure this mod...
Again thanks for the feedback
more is welcomed..
Old Jul 6, 2010 | 11:04 AM
Patsfan83's Avatar
Patsfan83
more is welcomed..
Does your car run any differently than prior to installing the tube?
This looks like a good idea on paper, Will it work with pop chargers?
Old Jul 6, 2010 | 09:25 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
You are on the right track here, corrugated tubing is not good for flow in the first place and the front of the car is well designed to pressurize the air in front of the radiator and force it through the radiator and air intakes. Those rounded squares around the intake holes in the radiator shroud are actually there to smooth the air flow into the box and increase flow.
Old Jul 7, 2010 | 06:18 AM
RedBullRR's Avatar
RedBullRR
This would be a cool idea for cooling the brakes down...
