DIY - CLUTCH INSTALL part II - JWT clutch
Old Feb 17, 2010 | 10:34 AM
resident25's Avatar
resident25
This is freakin awesome. I'm givin this to my mechanic since he's putting this in for me tomorrow. Thx for takin the time for this bro!
Old Feb 17, 2010 | 12:26 PM
JasonZ-YA's Avatar
JasonZ-YA
thanks man.....
ya the next clutch install i do, i plan on having a spare person there just to take pics to make a monster diy..
its really not that hard, its just scare to most is all..
-J
Old Apr 7, 2010 | 07:05 AM
candyman7's Avatar
candyman7
if my clutch comes in this weekend ill be tackling this job wish me luck
Old Apr 9, 2010 | 07:53 PM
zracing5469's Avatar
zracing5469
my jwt clutch came in today. installing tomorrow night. Hopefully i will remember to take some pictures to help everyone out. Now all i have to figure out is what a clutch does
Old Apr 14, 2010 | 04:50 AM
candyman7's Avatar
candyman7
n00b
Old May 20, 2010 | 10:16 AM
Band-Aid's Avatar
Band-Aid
I'm not sure if this is the proper place to ask thus question. I bought a JWT clutch a while back and shortly thereafter I was offered a sweet deal on a Nismo clutch and flywheel combo, with free install! My question is will a JWT clutch mate up to th nismo flywheel? Thanx for any info.
Old Jun 5, 2010 | 07:37 AM
marco_mendoza's Avatar
marco_mendoza
Thanks to this thread and the original, I was able to change the clutch and flywheel myself using modest tools. About the only time I needed help was to remove the tranny and put it back in.
I ran into a couple of problems, such are rounding out some exhaust bolts (should've soaked them with some Pb penetrator overnight), even with the tool rental from AutoZone I couldn't remove the throwout bearing (I went to a machine shop and they did it for 5 bucks!)but the directions are spot on!
Don't forget to remove the slave cylinder instead of the master cylinder. (I know there was an edit, but not on the Word attachment that I downloaded)
Once again, thank you to both of you, and I have a great satisfying feeling that I changed this myself!
Old Jul 14, 2010 | 11:23 AM
snowboarder599's Avatar
snowboarder599
Thanks for the write up! I totally needed it!
Old Aug 10, 2010 | 07:27 AM
djtodd's Avatar
djtodd
Default Torque for flywheel bolt
Just to clear up any confusion, the service manual calls for 88nm or 65ft-lb of torqe for the flywheel bolt.
As stated earlier, 93 may shear/strip them.
Old Aug 10, 2010 | 09:12 AM
zen350z's Avatar
zen350z
Flywheel bolts use the Blue Loctite, Look at the bolts when you pull them out, they have blue on them.
Old Sep 6, 2010 | 11:49 AM
louie12345's Avatar
louie12345
Thanks for the right up, installed my jwt clutch yesterday. It took me 6 hours from start to finish. This the first time that I change the clutch on a 350z. Did not remove the bracket as stated on 1A, I was able to get upper two bolts with no problem.
I suggest to remove the shifter, whatever pertaining to the interior of the car before you get your hands dirty. It was just a matter of romoving the bolt from the tranny (under the car)to release the shifter and push it up.
Old Oct 2, 2010 | 07:14 PM
Neu Era's Avatar
Neu Era
Great info!
Old Oct 3, 2010 | 07:42 AM
350zhr's Avatar
350zhr
how long would this take on a lift with a few mechanically inclined people working on it?
Old Oct 3, 2010 | 05:03 PM
Armed Ferret's Avatar
Armed Ferret
should only take 2, maybe 3 hours if you go slow.
Old Oct 7, 2010 | 05:14 AM
350zhr's Avatar
350zhr
has anyone installed a spec twin disk? mine has two indicators on the flywheel, one says front and the other says rear, right above the holes. Im installing it tomorrow and dont want to put it in wrong.
Old Oct 7, 2010 | 05:21 AM
JasonZ-YA's Avatar
JasonZ-YA
line it up with the dot that says REAR, ie, meaning rear wheel drive....
the front indicator is for maximas or some ish...
JWT clutches and many others also have two dots....in their supplied installation instructions it tells you to line up with "rear"
-J
Old Oct 7, 2010 | 12:22 PM
350zhr's Avatar
350zhr
thanks for the fast response. spec didnt send much for instructions.
Old Oct 18, 2010 | 08:09 AM
  #38
Royal_T's Avatar
Royal_T
Thanks for this write up Jason.
Well I did mine this weekend but ran into a problem. I only changed out my clutch though.
The problem I am having is this. I put everything back together but now it won't engage. When the car is off it goes into every gear just fine but when I turn the car on it won't engage fully. At once it was engaging in 1st-3rd but not 4th-reverse. What could it be?
Thanks
Old Oct 20, 2010 | 10:04 AM
  #39
Robert58b's Avatar
Robert58b
Going to do my son's this week-end. I also do not plan to do the flywheel if not needed. What was the problem you had with it not going into gear? Did you get is solved?
Old Oct 20, 2010 | 10:18 AM
  #40
JasonZ-YA's Avatar
JasonZ-YA
Thanks
what exactly was done? and were you there to see it happen?
1. did you change the through out bearing?
2. did you change the pivot ball? - if so, was it the right one? not the shorter one or longer one for specific year models???
Read here:
http://www.importpartspro.com/chclpiba20ni.html
2.5. - what year is your Z?
3. did you engage the metal retaining clip onto the pivit ball and through out bearing - do you hear any noise, rattling??
4. anything else pertinent??
I have a feeling his is a fluke install?? if all is done right you will be fine.....
as for you doing the clutch with out doing the flywheel that is completely fine given:
1. you change it out BEFORE/QUICK enough that the car is still drivable.......if the car has been inch'ing along, and your "finally getting around" to changing the clutch, then the flywheel will be to far gone along with the clutch pressure plate..
2. you remove the clutch and inspect the flywheel.........if with your fingers you can feel waves and imperfections, its no good..
-J
