DIY - Titek CF rad cooling plate
Old 09-19-2009, 06:24 PM
TPerry109
TPerry109's Avatar
Default DIY - Titek CF rad cooling plate
This really is the simplest thing to install next to an air freshener...mine just came in so was doing it anyway. Maybe this will help someone, in someway, sometime.
Tools needed:
Flat head screwdriver
Needlenose plyers
The part - titek cf rad cooling plate
Step 1:
Remove the 4 center plastic circular tabs on the front bumper.
If you haven't removed these before, just take your flathead edge and get under the center circle and pry it up. Pull the center circle about 3/4's from fully up position, this will allow the tabs underneath room to pinch in when you pull up on the clip.
Step 2:
Place the cooling plate in the correct position.
The titek plate came with a piece of foam with glue strip on one side.
I placed this where the back of the plate contacts the body to reduce movement/rattle because the clips keep the front of the plate secure.
Step 3:
Re-insert the 4 black clips into the holes. They will just slide right in if you keep the center circle in the 3/4 position then push the center down until it clicks. It will be tighter this time because of the thickness of the cf plate.
And you're finished. Give yourself a pat on the back for you're grueling 45 second install.
Old 09-19-2009, 07:46 PM
cwv_558
cwv_558's Avatar
We have the same carpet
Old 09-19-2009, 11:14 PM
w210e55
w210e55's Avatar
Default question
can you put the front of the cooling plate under the front bumper or should it go on top? or does it even matter?
Thanks
Old 10-07-2009, 07:08 PM
pminor87
pminor87's Avatar
where did you buy and how much was it? looks awesome by the way.
Thanks
Old 10-31-2009, 08:05 AM
basicblack@nola
basicblack@nola's Avatar
Smile
Great pics,short & to the point,sweet,thanks.
Old 11-04-2009, 01:02 AM
aloh
aloh's Avatar
hmmm i think you're supposed to put it underneath the front bumper...
Looks nice though.
Old 11-26-2009, 07:32 PM
Lee R
Lee R's Avatar
Phase 2 Motortrend has a great deal on this piece. I first installed it on top but it would slightly rub. So I put it underneath the bumper lip and it's fine.
Old 12-10-2009, 06:01 AM
350Z_Al
350Z_Al's Avatar
Thanks
I HAD to put mine under the bumper and I had to sand the bottom down a bit to thin it out or my hood wouldn't close... Even with the hood latch all the way up..
I think my Z's been hit in the front at one time in it's life and isn't perfectly lined up
Old 12-10-2009, 02:38 PM
AstroZombie
AstroZombie's Avatar
I made one of these at work and tucked mine under the bumper. I think it looks cleaner that way.
Thanks for taking the time to post!
Old 11-30-2010, 01:42 PM
stevez redline
stevez redline's Avatar
just add one thing... before you pry the plastic caps place a microfiber towel on top of the painted surface of the bumper to prevent accidental scratches...if you break the clips they are just like $2.00 from nissan
Old 01-24-2012, 07:18 PM
Z33Garage
Z33Garage's Avatar
Nice, I bought a sheet of aluminum from a local home depot.
Have not used it yet, so last night I went to the Z and made a stencil to make a cooling plate out of that metal. so far so good.
apex locator
07-23-2021 02:27 AM
Twenty4
01-17-2016 01:20 PM
SharX59
09-30-2015 10:54 AM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: DIY - Titek CF rad cooling plate
