DIY: Disabling VDC
Old Nov 30, 2010 | 04:23 PM
KingBaby's Avatar
KingBaby
Hardest Setting
ok found time to rip my car apart today...
what wire am I cutting in an 07 350z nismo?
anyone?
I'm going to look through the diagrams just asking to save time...
thanks
Old Dec 12, 2010 | 10:15 PM
mpact1981's Avatar
mpact1981
King baby, let me know or post a pic when you figure it out. I have an 08 and plan on doing mine when we are reunited in February.... lol
Old Dec 12, 2010 | 10:54 PM
KingBaby's Avatar
KingBaby
Hardest Setting
cool...I have everything prepared for it...
I've install a switch next to the traction control...
ran the wires and zip-tied everything nice and neatly next to the control box...
but I haven't had time to find out which wire it is...
so many little projects
Old Dec 16, 2010 | 04:56 AM
idrive_MD's Avatar
idrive_MD
Is there an orange wire coming from the VDC box behind the shifter? Sorry I couldnt be more help, I have a G35 obviously. I'm surprised it wouldn't be the same, but I guess the Z would have a slightly different interior harness due to length and feature differences.
Old Apr 14, 2011 | 07:20 PM
Alexl08's Avatar
Alexl08
Okay So i did this to the tee and for some reason during a brake stand EA drag strip the car still cuts power why is this?
Old Apr 14, 2011 | 08:00 PM
KingBaby's Avatar
KingBaby
Hardest Setting
What model do you have?
Which which wire did you cut?
Old Apr 18, 2011 | 05:42 AM
Alexl08's Avatar
Alexl08
I have a 2003 track model. I cut the orange wire and the traction control part works great. But when your on gas and brake EA trail braking or Brake stand it cuts throttle. I believe this is some kind of safety feature.
Old May 9, 2011 | 10:57 AM
djamps's Avatar
djamps
What you're dealing with is brake override... you know, 'brake always wins' -- the thing that might have saved Toyota from all their recall madness LOL it has nothing to do with TCS/VDC.
You need to either pull the brake fuse (easy, but you will have no brake lights) or wire a switch in line with the brake line going to the ECU so your brake lights still work and you have a switch for it.
Either method stops the brake signal from reaching the ECU and you can burn out all day long. I put my switch in the gauge pod for easy access at the track.
Old Jun 10, 2011 | 03:11 PM
sportbiketed's Avatar
sportbiketed
So if the switch is in the on position the the system is functioning normally?
Old Jun 10, 2011 | 03:43 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Supposedly!
I lost the links to wiring of the car. Who has the links to the PDF. files for the whole car?
Old Jun 16, 2011 | 06:25 PM
sportbiketed
Finally got around to taking a pic. The orange vinyl is just temporary until I get some black vinyl or paint. I'm also thinking about changing the switch to a plain black one.
Old Sep 3, 2011 | 09:07 PM
JDMStanced's Avatar
JDMStanced
i finished installing this.
You won't be able to turn off VDC (no lights on the dash) when the car is still running.
When i turned ON VDC (lights on the dash) and then OFF, ABS light comes on and goes away. Is this normal? I took a video of this. The video starts with the switch in OFF position.
http://s785.photobucket.com/albums/y...t=IMG_1471.mp4
Old Sep 6, 2011 | 05:10 AM
idrive_MD's Avatar
idrive_MD
Its been a while since I did my install and actually the first time I had an issue as you might have read. I think my abs light does flash when it is off and then turned back on, but the VDC will still be off until you recycle the ignition/engine and reset the switch before you turn it back on. Make sense?
Old Mar 18, 2012 | 08:38 PM
TehkMob's Avatar
TehkMob
Not to bring this back up but!
I think the the vdc works with the abs so when you kill the vdc it affects the abs as well right? Any comments on this? I just bought another z and I hate the vdc. I miss my base z with no tcs or vdc. Is there a way to convert to base model equipment and not have you gauges lit up all stupid with warning lights?
What if I take the box out completely? Anyone tried this? Any comments or concerns?
AnywYs, damn I iss my base model haha..
Old Mar 18, 2012 | 08:47 PM
sportbiketed
Abs is not affected
Old Sep 18, 2012 | 06:15 PM
padilla03z's Avatar
padilla03z
sorry to bring up this old thread but isnt the abs what causes the understeer after touching the brake before a corner or is this the vdc? i could care less about stand still burnouts. i just want to get rid of the understeer while on the track, that isnt part of the car or my braking technique.
Old Sep 18, 2012 | 08:06 PM
sportbiketed
shitty tires+inexperienced driving=understeer
Old Sep 18, 2012 | 09:49 PM
  #38
padilla03z's Avatar
padilla03z
why are u tryin to flame bro im askin a simple question? i didnt say i was a pro driver but the car had something to do with my understeer, not my driving. best motoring even noticed it in 2003 when they tried the car out and there not amateur drivers
Old Sep 19, 2012 | 02:19 AM
  #39
mhoward1's Avatar
mhoward1
Oh really? Love to hear how the type of tire used effects under vs oversteer.
Back on topic, most of the 350Zs understeer comes from the tire staggerded setup. A square setup gets rid of almost all of the push. You will need to be prepared for rotation though.
Old Sep 19, 2012 | 08:51 AM
  #40
sportbiketed
*Shitty tire sizes
