Build guide/supercharger install!!
Old Aug 13, 2015 | 08:53 PM
04Z34's Avatar
04Z34
Default Build guide/supercharger install!!
Hi everyone I'm new here!
I have a 04 350z, I am installing a Vortech V2 supercharger with supporting mods. I already have a plenum spacer and test pipes , with stillen strut bar. Coming with the supercharger will be a Osiris tune, cat back exhaust, bigger injectors 300-440cc, and I aftermarket fuel pump haven't decided! Now I bought this kit used from the states and it's a complete kit but it needs a cog belt (45$) and supercharger needs a bearing kit (200-350$). I will take any info on aftermarket parts! Supporting mods! Info on what to look for and what to avoid! Helpful info on the install and the bearings in the supercharger. First time installing a supercharger and first time rebuilding the supercharger! I'm gonna have updates and pics and tons of write ups on how this is going! Staying posted and helping out as I go would be appreciated! I pick the supercharger up tommorow , will add photos of the used kit after I clean up and sort! Step 1 will be order cog belt and step 2 is rebuild supercharger! Gonna be a long haul here! Any info is need on anything regarding this topic! Thanks alot☺️☺️☺️
Old Aug 19, 2015 | 02:17 PM
NissanZcrazy's Avatar
NissanZcrazy
My advice would be to buy a working kit so you don't run into lots of complications.......
Old Aug 20, 2015 | 12:27 PM
350z-Helsinki's Avatar
350z-Helsinki
Vortech has pretty good installation instructions so I would start there. I would select bigger injectors. Stock gt-r or dw600. If ethanol is an option the ID1000 would be a good choice. You will also need an oil cooler and a thermostat. I would go with at least 25 row mocal/setrab. Then a bigger radiator if you will ever track the car. A fuel return kit like CJM stage 0 and then you need an Uprev maf. I think that includes the essential stuff. Then of course a good tune and some cash when the stock block gives up.
350Z_Al
Oct 29, 2020 07:44 PM
