swapping in HR motor ?
Old Nov 7, 2007 | 03:32 PM
ProjectPSI's Avatar
ProjectPSI
Default swapping in HR motor ?
Well I'm looking for a motor for my 03 z to build over time and then swap into the car without too much downtime. Looking into a stroker twin turbo setup.
Found a real good deal on a motor but it is a 05-06 rev-up motor. What is the difference as far as wiring, fitment, and mounting between the two motors? Is it worth the trouble or just keep looking for a non rev-up motor?
Tries searching but came up with nothing as far as the swaps are concerned. Any help will be appreciated.
Old Nov 7, 2007 | 04:11 PM
QuadCam's Avatar
QuadCam
there weren't any 05-06 HR motors!
The HR came out in 07 and was only available in the G35 Sedan and the 6mt 350Z.
Old Nov 7, 2007 | 04:12 PM
Sean's Avatar
Sean
maybe he means rev-up?
Old Nov 7, 2007 | 04:26 PM
ProjectPSI's Avatar
ProjectPSI
yes i do mean rev up, i thought the hr and revup were the same. i stand corrected.
Old Nov 7, 2007 | 04:29 PM
Sean's Avatar
Sean
don't forget the oil issue before you buy a motor.
Old Nov 7, 2007 | 04:49 PM
SpoilsofWar's Avatar
SpoilsofWar
A lot of the available rev up long blocks on the market may be dealer take outs due to excessive oil consumption. But, this is less of an issue since he plans on building the engine with a stroker kit.
Old Nov 7, 2007 | 05:17 PM
ProjectPSI's Avatar
ProjectPSI
The motor im looking at is a nissan warranty motor due to oil problems. I plan on rebuilding the whole thing anyways so im not really concerned with that like you stated. Just need to know if i will have issues swapping it in or not.
Thanks for all the input so far guys.
Old Nov 7, 2007 | 05:24 PM
punish_her's Avatar
punish_her
From what I understand all you would need is a REVUP ECU and engine harness because the CAN systems are the same. It wasnt until the HR's where all the cars computers were changed.
So all you realy need is ECU and engine harness.
If you are goint to stroke it will be more of a pain in the *** to swap to the revup. I'd say stick with the 03-05 VQ35DE you wont have to change any of your cars wiring harnesses.
All else fails man dump in a VK56DE. A built and tuned 5.6L V8 will get you ALOT of power. Toss in a plower or Turbo and you got some SICK power. That will take some $$$ though.
Old Nov 8, 2007 | 09:01 AM
ProjectPSI's Avatar
ProjectPSI
Thats kinda what I was afraid of. Anyone else care to chime in on this?
Old Nov 11, 2007 | 06:30 PM
track1z's Avatar
track1z
Yah its a ****ing mess! don't do it unless you have the WHOLE wreacked car!
SharX59
Sep 27, 2015 09:23 AM
