Engine Swaps For all your engine swap experiences, ideas, questions, & more..
2jz 350z
Old 05-25-2015, 07:42 AM
  #41
rustyschopshop
rustyschopshop's Avatar
Keep up the phenominal work, great progress.
Old 05-27-2015, 08:13 AM
  #42
IanP
IanP's Avatar
Thanks guys
Downpipe is on and looks like it will need minimal adjustment to make it fit a 350Z exhaust.
Just waiting on the custom propshaft being made.
In terms of power figures, my target is 700hp and 700 torque. The Syvecs will allow us to have 8 different maps so I will have a few power settings
My mapper seems to think we will be closer to 900-950hp.
I've seen a few youtube videos of the turbo I'm using and they have all made around 850 RWHP
Old 05-28-2015, 06:47 PM
  #43
midz350
midz350's Avatar
Couple of advices, get or weld 90 degree turbo compressor ( 90 coupler would burn or blow off), sell the 264 And get 272 cams, bigger injectors, connect the Syvec to the Z CAN BUS to get the OEM tacho to work and to change maps and boost and do rolling launch by the steering wheel buttons.
The highest S366 on a 2jz I have seen is putting around 850whp. I'm aiming for low to mid 600whp on 91oct with the same turbo and 272 Titan cams.
Old 05-28-2015, 07:22 PM
  #44
IanP
IanP's Avatar
I did consider upgrading to 272 cams but everything I've read about them says that on a road car they effect drivability too much - my supra was a butch to drive at low speeds with the 264s.
Injectors have already been upped to 1000cc.
Will look into the syvecs thing, would be a lot easier than getting the race tech dash fitted.
Old 06-07-2015, 05:27 AM
  #45
NOLAGG
NOLAGG's Avatar
Any other updates?
Old 06-07-2015, 08:54 AM
  #46
Classy
Classy's Avatar
Subscribed
Old 06-07-2015, 03:25 PM
  #47
NOLAGG
NOLAGG's Avatar
What swap kit did you use? Also what was or had to be done to get it to fit and leaving your shifter assembly in the center?
Old 06-13-2015, 04:38 AM
  #48
IanP
IanP's Avatar
Returned home from holiday to a few nice packages
Tarmac supplied a Mine's lip
Looks pretty well made, as most of you will remember I had a genuine CF Mine's lip n my last car that I destroyed due to it being so low and with this car being even lower I dont fancy destroying another carbon one :lol:
Jez @ Horsham supplied me with a 350Z syvecs harness. This will allow us to use the stock dash cluster instead of switching to the race tech (Race tech was way too much hassle for me to be arsed with!)
FMIC is mounted and new headlights are installed
Custom turbo side intercooler pipe made
Fuel lines have been run, FPR installed, OEM inlet fitted - Just waiting on the throttle body to arrive to finish the intercooler piping
Old 06-13-2015, 04:53 AM
  #49
RUNWDVL
RUNWDVL's Avatar
In for the win....
Old 06-19-2015, 10:39 AM
  #50
Godfoot
Godfoot's Avatar
Found the thread!! WOW! So much incredible work!! Can't wait to see this lady run. Sub'd FOR SURE!
Old 06-19-2015, 11:39 AM
  #51
NOLAGG
NOLAGG's Avatar
What shifter assembly are you using? Ands what didn't you use the stock 2j mounts and brackets?I heard they work. Last but not least, was cutting the cross member and re welding the lip on it definitely necessary? Thanks ands build looks awesome
Old 06-22-2015, 01:50 AM
  #52
IanP
IanP's Avatar
Shifter assembly is stock and will probably be modified to move it back to the stock location.
Didn't know that the stock 2J brackets and mounts fit - never seen anyone say that they do?
as for cutting the cross member - The 2JZ sits a lot lower than a VQ and the space in the cross member is required for the oil pan to sit into - without this space then the engine wont fit
Old 06-22-2015, 05:08 AM
  #53
NOLAGG
NOLAGG's Avatar
Oh ok I was asking because I'm about to pick up my motor set this Thursday and prepare for the swap. The only thing is I'm going to use my cd009 trans with collins adaptor plate and shortened shifter and was thinking whether or not I'm going to have to modify the cross member since the motor well most likely have to sit up front closer to the rad support vs yours which sits low and closer to the fire wall.
Old 06-22-2015, 07:43 AM
  #54
graffkid732
graffkid732's Avatar
With front sump pan I didn't have to cut anything. I am using the Getrag trans as well not a Z trans.
Old 06-22-2015, 07:52 AM
  #55
IanP
IanP's Avatar
I'm using Z transmission
The sale of the V160 paid for me to buy the Z
We also had to change to the oil pan from an Aristo as there are 3 different 2JZ sumps.
Old 06-22-2015, 08:25 AM
  #56
NOLAGG
NOLAGG's Avatar
Ok cool,I just wanted to make sure .What pan/dunno did you use? And did you modify the trans bracket?
Old 06-22-2015, 08:43 AM
  #57
graffkid732
I will be making a custom trans bracket as I don't have the Supra bracket and I'm pretty sure I got rid of the Z trans bracket when I sold the trans.
Honestly, I forgot. I don't remember which car they come out of. Titan has them and all I asked for was a front sump pan setup.
Old 06-22-2015, 11:01 AM
  #58
NOLAGG
NOLAGG's Avatar
Messaged you graff
Old 06-22-2015, 08:34 PM
  #59
StevSam
StevSam's Avatar
This is beautiful! Subbed.
Old 08-26-2015, 11:35 AM
  #60
IanP
IanP's Avatar
So this arrived at my house today
figured I may aswell have a bit of a tidy up. this is just some of the stuff that came out of the car
decided to chuck the front bumper on just because (I'm still sorting through bags of bolts trying to find everything hence why its not "fitted"!
Test fitted my spark plug cover
Chucked a seat in to free up some garage space
Custom prop shaft
Defi gauge in the door vent
Battery relocation. Still need to buy a smaller battery
Custom power steering tank hidden away, catch can to also be mounted here
So now comes the dilemma.
I've been in discussions with another garage to finish it off for me but it wont be until later this year/early next year. If I do go ahead with it then I will be making a few changes to the spec of the car.
Depending on the outcome of the cost discussion then I may still end up breaking it.
Either way, its home with me now and I can take my time to decide what I'm doing
Resmarted (08-26-2015)
Quick Reply: 2jz 350z
