Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2jz swap
Old Oct 21, 2017 | 05:05 PM
  #41
chase z's Avatar
chase z
Old Oct 30, 2017 | 11:34 AM
  #42
chase z's Avatar
chase z
All most there
Old Oct 30, 2017 | 11:57 AM
  #43
CK_32's Avatar
CK_32
As much as I love the VQ, this is why I always say, 2j / LS EVERYTHING!
Good to see a proper build on this forum. Like Trav said, too many penny kids with big dollar dreams.
Old Nov 1, 2017 | 01:31 PM
  #44
chase z's Avatar
chase z
thanks man.
after this build I think I might make a drag car. Gen 1 rx7 or 90s 300zx and maybe a ls or a 1uz or 1gz. All turbo of course
Old Nov 1, 2017 | 01:48 PM
  #45
bealljk's Avatar
bealljk
Great fab work ... sub'd for sure!
Almost picked up a eastwood machine bc theyre so inexpensive and a tiny entry cost to get your feet wet. Ended up with a everlast tig ... surprising how good they are. And a decent band saw make all the difference ...
are you going to run OEM engine mounts long term?
Old Nov 1, 2017 | 02:09 PM
  #46
chase z's Avatar
chase z
I made some solid mounts after I seen how much the oem flexed
Old Nov 3, 2017 | 06:42 PM
  #47
chase z's Avatar
chase z
After spending some time making sure it was 100% timed right it had it first start
Old Nov 5, 2017 | 12:33 PM
  #48
chase z's Avatar
chase z
I have a back feeding problem form the ignition that I have to fix. I hate wiring problems.
Old Nov 10, 2017 | 01:24 PM
  #49
chase z's Avatar
chase z
The space was tight for the intake from the intercooler. In had to pie cut the bend and oval out part of it and cut and weld in a flat plate to make enough room for the headlight to fit.
Old Nov 10, 2017 | 08:16 PM
  #50
bealljk's Avatar
bealljk
them some crazy pie cuts!!!!
do you wear gloves when you TIG?
Old Nov 11, 2017 | 04:01 AM
  #51
chase z's Avatar
chase z
for most tacks naw but for everything else I do. But I use cheap thin harber freight gloves.
Old Nov 11, 2017 | 07:21 AM
  #52
bealljk's Avatar
bealljk
The reason I ask is - I wore a pair of thin cow-hide gloves for a while and then I went glove-less and it felt way more comfortable ... I do wear a pair of (harbor freight) latex/rubber gloves to keep the argon scent off my skin.
I'd say try it if the gloves are getting in the way -
Old Nov 11, 2017 | 05:06 PM
  #53
chase z's Avatar
chase z
I burn my self when I don't use gloves lol
Old Nov 11, 2017 | 05:11 PM
  #54
chase z's Avatar
chase z
I still have to weld in a brace and 2 more mounts for the bottom
Old Nov 11, 2017 | 05:12 PM
  #55
bealljk's Avatar
bealljk
you will quickly learn not to! Keep up the lords work!
Old Nov 11, 2017 | 06:02 PM
  #56
chase z's Avatar
chase z
U would think that but I grab **** with out thinking so I keep gloves on!
Old Nov 12, 2017 | 07:44 AM
  #57
chase z's Avatar
chase z
Put in the lower intercooler mount this thing is solid. And mocked up the pie cuts some more for the piping. I was going to do pie cuts for the turbo to intercooler piping as well but I decided not to for how long it takes and u will never see it with the bumper on.
Old Nov 13, 2017 | 01:49 PM
  #58
chase z's Avatar
chase z
Old Nov 13, 2017 | 02:03 PM
  #59
Conway_160's Avatar
Conway_160
So whats better a push or pull fan set up? Or is this purely do to the lack of room you have behind the radiator?
Old Nov 13, 2017 | 02:17 PM
  #60
chase z's Avatar
chase z
pull is better. Yea that's why I have pushers I need to order one more
