Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Possible ECU problem? Car won't crank on one ECU.
Old Jan 3, 2018 | 08:30 PM
Cricketz's Avatar
Cricketz
Default Possible ECU problem? Car won't crank on one ECU.
These past 3 days have been packed with intensive engine swapage. I bought a salvaged title 05 Revup with a stillen supercharger and tons of other stuff done to it. Also, I bought a clean title 03 shell. I've done the entire engine swap, but I have some issues with fuel. The ECU I took out of the 05 seems to not push any fuel when cranking. The fuel pump does prime just fine though. As soon as I swap to the 03 ECU though it starts up just fine. I took the 05 engine harness and everything from the other car.. I couldn't find anything about this specific issue. I've heard programming keys to the other ECU. Is that what I need to do to fix this issue?
Old Jan 4, 2018 | 02:31 AM
Conway_160's Avatar
Conway_160
The key needs maped to the ecu or NATS won't allow it to start. I'm not sure if it kills fuel or spark but it wont allow it to start.
Old Jan 4, 2018 | 06:46 AM
seymore4's Avatar
seymore4
Professional
You need to reflash the ECU with Uprev and disable NATS. PM me if you have any specific questions
Old May 23, 2018 | 06:08 AM
wizard's Avatar
wizard
As said - apparently you can disable the nats with uprev,
tjchawla
NISMO 350Z
Dec 18, 2007 06:32 AM
VN_350z
Jun 1, 2006 07:19 AM
Acree
Mar 23, 2006 01:57 PM
Tekwon-V
Dec 2, 2005 05:11 PM
Jergens
Nov 29, 2004 10:30 AM
