Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Vq35de rev up block with vq35de non rev heads
Old Oct 14, 2020 | 08:50 PM
ssmokeyy's Avatar
ssmokeyy
Default Vq35de rev up block with vq35de non rev heads
I have a 04 350z track model. I want to update my engine. I have look but it seems like every one wants to try rev up heads on non rev block. I want better block. Has anyone ever used a rev up or hr block with non rev heads?
if not is the pathfinder coolant mod the best for the non rev block?
Old Oct 15, 2020 | 09:11 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Sorry to say, there is no better shortblock than the one you already have. The VQ35DE won plenty of Wards Automotive design awards from 2003-06, and there's no real advantage to swapping unless the engine is damaged. The HR block is quite different internally, so don't even consider a swap there.
Old Oct 16, 2020 | 11:08 PM
ssmokeyy's Avatar
ssmokeyy
I know the hr is different. Just trying to do every upgrade I can to the engine when I rebuild it. I read a lot about the coolant getting real hot by the rear cylinders so I was thinking maybe new block they might have fixed that.
Old Oct 17, 2020 | 04:07 AM
Vas_Z33's Avatar
Vas_Z33
Build the DE block and run the Pathfinder cooling mod. Save the headaches.
Old Oct 17, 2020 | 05:26 AM
dnash's Avatar
dnash
You can use the HR head gasket and machine the coolant passages. This will change the coolant flow to be more like the HR.
350z_drifter
Dec 27, 2006 03:29 PM
