Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Ls1 swap on uk right hand drive 350z
Old Oct 18, 2021 | 12:09 PM
Nismoandy's Avatar
Nismoandy
Default Ls1 swap which clutch would You recommend daily
Hi there my name is Andy and I've completed the swap and the engine is running lovely, I have a problem though with the clutch i think it is contaminated and even since I've been driving the car it has a juddering when you engage gears but once engage it's fine so I'm going to take the gearbox out and replace it with another clutch can I have some recommendations on a replacement clutch. If it helps the engine produces 450 bhp and a cd09 gearbox, many thanks Andy
Last edited by Nismoandy; Oct 22, 2021 at 12:59 AM. Reason: Trying to ask members for their advice
Old Oct 18, 2021 | 03:53 PM
Ponyryd's Avatar
Ponyryd
What are you using for a trans? If it’s adapted to the stock unit I would be looking at the adaptor plate/install as step 1.
Old Oct 18, 2021 | 09:35 PM
Nismoandy's Avatar
Nismoandy
hi thanks for your reply I have a cd09 transmission can you please explain what the problem might be with the adapter plate? Photo of the adapter plate
Old Oct 20, 2021 | 08:20 AM
midz350's Avatar
midz350
If the clutch plate contaminated it would be slipping at high load not while shifting. Maybe check the slave cylinder, bearing and fork.
Is it using 350z clutch? Southbend has a lot of single plate clutches that are good for up to 800+ Ft-Lb and they drive good and not too expensive.
JUSTINC2001
Mar 17, 2022 08:28 PM
aireq
Feb 20, 2019 04:42 AM
DaytonaBlueZ33
Nov 7, 2016 04:10 AM
CK12983
May 13, 2016 06:27 PM
350Z_GTS
Aug 4, 2008 05:53 AM
