Engine Intakes, Exhausts, Clutches, Turbos, etc...
COSWORTH || TOMEI || WISECO || MAHLE *** Engine Rebuild Parts
Old Sep 18, 2008 | 08:09 PM
RavSpec's Avatar
RavSpec
Vendor - Former Vendor
Default COSWORTH || TOMEI || WISECO || MAHLE *** Engine Rebuild Parts
Jan 2010, Cosworth Special Price
CI8019 - Cosworth Nissan VQ35 short block 11:1CR
PM For Special Price
KK3918 - Cosworth Nissan VQ35 Big Valve Cylinder heads
Dec 17, 2009 *** Updated with new price and new parts / Contact us for combo price !! ****
SHORT BLOCK
Cosworth Nissan VQ35 High Performance Short Block 3.5L -Low Compression (8.8 : 1) - $7828.00 shipped
Cosworth Nissan VQ35 High Performance Short Block 3.5L -High Compression (11.0 : 1) - $7828.00 shipped
Nissan VQ35DE (350Z-G35) High Performance Short Block 3.5L The Cosworth VQ35DE high performance short block is the perfect foundation for your high performance application. Each High Performance Short Block is hand assembled by one of Cosworth’s skilled engine builders to exact specifications utilizing all new components and is available in either high compression 11:1 or low compression 8.8:1 for turbo or supercharged applications. To ensure smooth operation throughout the entire RPM range, each rotating assembly is carefully balanced, an essential requirement for high performance VQ35s. Additionally, comprehensive build sheet listing all critical dimensions is included. Use with our CNC ported Big Valve Cylinder Heads for maximum reliable performance.l
CNC Ported Big Valve Clyinder Heads
Cosworth Nissan VQ35 CNC Ported Big Valve Cylinder Heads (including Rev Up Engine) - $4404.00 shipped
Cosworth VQ35 CNC ported cylinder heads feature dyno tested and flow bench proven ports, engineered for maximum real world power. Each new cylinder head is ported on a 5 axis machine to ensure consistency and perfect port shape every time. Additionally, larger intake (+1mm) and exhaust valves (+1mm) are utilized to help increase flow. Cosworth CNC ported Big Valve cylinder heads come complete with a performance valve job, hi rev (max 10,500rpm) valve springs with titanium retainers and are ready to install. Perfect for big turbo applications or strong normally aspirated engines. Nissan VQ35 heads are priced for the pair. A flow chart for the head is available by downloading the technical document on the left.
Cosworth Camshaft Set (2 x intake and 2 x exhaust)
Cosworth Nissan VQ35 "287 HP" ZK1 Grind (268/268) - $1283.00 shipped
Cosworth Nissan VQ35 "287 HP" ZK2 Grind (270/270) - $1283.00 shipped
Cosworth Nissan VQ35 "Rev Up" ZK1 Grind (268/268) - $1283.00 shipped
Cosworth Nissan VQ35 "Rev up" ZK2 Grind (270/270) - $1283.00 shipped
Cosworth Forged Pistons and Ring Set
Cosworth Nissan VQ35 Low Compression Pistons and RING SET (95.5mm or 96mm) - $1312.00 shipped
Cosworth Nissan VQ35 High Compression Pistons and RINGs SET - (95.5mm or 96mm) - $1312.00 shipped
The piston is one of the most important components within an engine. It can be subjected to directional change up to 285 times every second and must withstand acceleration forces up to 8500g. Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth forged pistons are manufactured using the same methods as our Formula One pistons and feature friction reducing skirt coating, ultra strong pins, polished tops and patented anti-detonation bands. Additionally, each application uses a unique forging to minimize weight and ensure the strongest possible piston design. • Proprietary Cosworth alloy • Popular sizes • Unique forging • Skirt coating • Polished top • Anti-detonation bands • High strength pin
Others
Cosworth Nissan VQ35 Main, Rod and Thrust Bearing Sets (std or race) - $283.00 shipped
Cosworth Nissan VQ35 High Performance Valve Springs Set - Single Valve (24) (20000163) - $463.00 shipped
Cosworth Nissan VQ35 High Performance Valve Springs Set - Ultra High RPM / Dual Valv + Titanium Retainer Set - $1131.00 shipped
Cosworth Nissan VQ35 Forged Connecting Rods (set of 6) - $1377.00 shipped
Cosworth Nissan VQ35 Head Gasket Kit (Pair) / 96mm or 98mm or 100mm Bore - 0.6mm Thickness - $262.00 shipped
Cosworth Nissan VQ35 Head Stud Kits - $285.00 shipped
Cosworth Nissan VQ35 High Pressure Oil Pump Kit - $547.00 shipped
Cosworth Nissan VQ35 High Pressure Oil Control Baffle - $72.00 shipped
Cosworth Nissan VQ35 High Pressure Oil Control Baffle w/ (03~04 install kit) - $100.00 shipped
Cosworth Nissan VQ35 Twin Plenum Intake Manifold (non polish) - $1248.00 shipped
Cosworth Nissan VQ35 High Volume Fuel Rail Kit - $475.00 shipped
New Cosworth Rods features :
* Packaging is improved to industry standards and a detailed data card included.
* Rods now include genuine Cosworth H11 tool steel rod bolts (260,000psi).
* Proprietary forging made in the USA.
* Detailed machined work to maintain optimum weight and strength.
* Solid Bean design for high power applications
* “Radial Truss” small end for superior strength and reduced reciprocating mass
Old Sep 18, 2008 | 08:28 PM
RavSpec's Avatar
RavSpec
TOMEI Camshaft VQ35 DE or HR Engine (256, 264, 272, 280) Lash Type - $1088.00 shipped
Detail Spec Including Dyno Result
The PROCAM series are for the serious users who need results when every milli-seconds count. The heart of the VQ35 NA engine lies with the camshafts. The camshafts are the key starting point for tuning this engine. Our camshafts will give you the best driving experience and the overall satisfaction with your VQ35 engine. These camshafts will change the characteristics of your engine and give it a more race feel and response. Not for the faint hearted and will require professional setup and installation.
Note: 272 and 280 camshaft required valve spring upgrade ( >11mm lift)
TOMEI Forged H Beam Connecting Rod (6 piece set) - $1199.00 shipped Per Set
SMC4329 material, ARP rod bolts are used. Extra oil holes to further increase lubrication efficiency
TOMEI Head Gasket VQ35 96.7mm bore / 0.7mm Thickness - $358.00 shipped Per Set
Super Grommet
Made from 100% metal with the bead type design for the perfect seal. Our metal head gaskets have been a very popular selling product with the multilayered metal design with proven success. Our VQ35 gasket has outstanding reliability with the super grommet design used around the bore area for reassurance.
(Super Grommet = Bead Structure and Metal Grommet dual system seal)
■ Designed for φ96.2mm Bore Size.
This gasket is 0.5mm oversize to become φ96.2mm setting. For use with piston sizes up to φ95.7mm
MAHLE Piston and Ring Set ** top and side coating to reduce friction and noises
********** AVAILABLE APPLICATION **********
- Mahle Low Compression (8.5:1) 95.5mm Bore Pistons and Rings Sets - $759.99 shipped
For over 60 years Wiseco has been manufacturing the finest aftermarket forged pistons & performance parts for the snowmobile, motorcycle, ATV, personal watercraft, outboard marine, karting and automotive markets.
1. Valve Pocket designs that allow maximum flow around valve, also allowing oversized valves and high lift cams to be utilized.
2. 2618 extruded material forged for the maximum strength available.
3. High quality piston rings featuring alloy steel contrusction on top ring, cast iron taper faced 2nd, and 3PC oil assembly utilizing atainless expander and carbon steel rails.
4. Wrist Pins constructed of chrome moly steel material for ultimate in strength.
5. No wait time, most piston are available in stock.
- Wiseco VQ35 Low Compression (8.8:1) 95.5mm or 96mm Bore Pistons And Rings Set - $615 shipped
- Wiseco VQ35 High Compression (11:1) 95.5mm or 96mm Bore Pistons And Rings Set - $615 shipped
Eagle Connecting Rods (VQ35) Set of Six $550 shipped
K1 Connecting Rods (VQ35) Set of Six $570 shipped
Old Oct 7, 2008 | 07:05 PM
Obsidianice's Avatar
Obsidianice
I'm just looking at what I consider to be a mild build. Would you recommend the Mahle or the Wiseco pistons? I'm looking for the low compression. Not wanting to go with cosworth cause that's more piston that i need for my application.
Old Nov 8, 2008 | 10:55 PM
RavSpec's Avatar
RavSpec
quick bump ...
Old Dec 4, 2008 | 08:19 PM
RavSpec's Avatar
RavSpec
quick bump ..
Old Dec 11, 2008 | 06:16 PM
wenlipai's Avatar
wenlipai
hey what's your best price if i purchase Cosworth Nissan VQ35 Low Compression Piston and RING SET 95.5mm, Cosworth Nissan VQ35 Main and Rod Bearing Sets, Cosworth Nissan VQ35 High Performance Valve Springs Set (24), what's your best price for me? ship to CA91007
Old Dec 13, 2008 | 06:19 AM
RavSpec's Avatar
RavSpec
I'll pm you shortly, Thanks.
Old Dec 19, 2008 | 12:01 PM
RavSpec's Avatar
RavSpec
Weekend Bump!
Old Jan 9, 2009 | 02:25 PM
RavSpec's Avatar
RavSpec
Weekend Bump!
Old Jan 16, 2009 | 02:02 PM
RavSpec's Avatar
RavSpec
Weekend Bump!
Old Jan 23, 2009 | 02:31 PM
RavSpec's Avatar
RavSpec
Weekend Bump!
Old Jan 30, 2009 | 02:38 PM
RavSpec's Avatar
RavSpec
Weekend Bump
Old Feb 9, 2009 | 11:16 AM
deckdout2's Avatar
deckdout2
Do you have Eagle Rods as well? Could you shoot me a pm with your best price for The Rods and Weisco Pistons High Compression for the VQ35DE shipped to 28213? Thanks.
Old Feb 10, 2009 | 09:25 AM
RavSpec's Avatar
RavSpec
Pm'd, Thank you.
Old Feb 10, 2009 | 05:24 PM
jtgli's Avatar
jtgli
Pm me a price for Eagle rod and weisco pistons 8.8:1 to 17057 thanks
Old Feb 11, 2009 | 02:37 PM
RavSpec's Avatar
RavSpec
PM'd you back, Thank you.
Old Feb 20, 2009 | 01:30 PM
RavSpec's Avatar
RavSpec
Weekend bump.
Old Mar 27, 2009 | 01:09 PM
RavSpec's Avatar
RavSpec
Weekend Bump.
Old Apr 3, 2009 | 02:12 PM
RavSpec's Avatar
RavSpec
Weekend Bump.
Old Apr 10, 2009 | 08:06 AM
RavSpec's Avatar
RavSpec
Weekend Bump!
