VQ35 Engine Rebuild Packages From Z1
Vendor - Former Vendor
We've put together 3 basic rebuild / upgrade packages that allow you to select the level of performance you wish to include in your next build. These kits contain quality parts from Wiseco, Eagle, ARP, Cometic, ACL, and use Nissan OEM gasket kits. We of course offer these parts individually and have all other engine parts available as well.
Z1 VQ35 Basic Engine Rebuild Kit Level 1 $998.00
Our most basic package, contains Eagle rods and Wiseco pistons. The "building block" of a solid bottom end build. Pistons are available in shelf stock bore sizes or custom and can be ordered in 8.8:1 compression for TT builds or 11:1 compression for NA builds. Custom ratios are available for special order. Wiseco rings, locks, and wrist pins are included.
Z1 VQ35 Basic Engine Rebuild Kit Level 2 $1398
This package contains the basics from Level 1 and adds a full OEM gasket set with the option to upgrade to Cometic head gaskets along with a set of ACL Race Series Engine Beaerings.
Z1 VQ35 Basic Engine Rebuild Kit Level 3 $1788
This package goes one step farther by adding ARP head and main studs and a set of Z1 Viton Valve Stem Seals.
All three kits can be found Here.
We can get Mahle or JE pistons but when it comes down to quality vs. price we feel Wiseco is the best on the market. We have Wiseco pistons in numerous builds in both VQ and VG applications making as much as 1200 HP and have not had a single piston related failure.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
