Engine Intakes, Exhausts, Clutches, Turbos, etc...
FS: Momentum Performance inventory for Cheap! Turbo Kits/Headers/Exhaust
Old Jun 4, 2012 | 01:28 PM
National Speed's Avatar
National Speed
Vendor - Former Vendor
Exclamation Momentum Performance inventory for Cheap! Turbo Kits/Headers/Exhaust
Hey MY350Z! We have extra inventory we initially bought from Momentum Performance for sale at the lowest prices you'll find!
- First up, we have a total of 5 sets of Momentum Performance Headers left in stock. They are all sold as-is with no instructions included. $699!
Momentum Performance inventory for Cheap! Turbo Kits/Headers/Exhaust-mtqxt.jpg
Each header features true merge style collectors and equal length runners in order to maximize scavenging and efficiency while also reducing back pressure. Increased exhaust gas throughput translates into more horsepower for turbo and NA motors – a guarantee that is backed by thousands of miles of track testing. Momentum Performance headers are built out of TIG welded, mandrel bent 304 stainless steel and feature three-eighth inch thick stainless steel flanges for maximum corrosion protection and strength. Each header features true merge style collectors and equal length runners in order to maximize scavenging and efficiency while also reducing back pressure. Increased exhaust gas throughput translates into more horsepower for turbo and NA motors – a guarantee that is backed by thousands of miles of track testing. Momentum Performance headers are built out of TIG welded, mandrel bent 304 stainless steel and feature three-eighth inch thick stainless steel flanges for maximum corrosion protection and strength.
- 304 grade, 16 gauge stainless steel construction
- 1 3/4” equal length primaries into 2 1/4” outlet
- Maximum airflow, race proven merge style collectors
- Back purge, TIG welded for the ultimate in durability, performance and visual appeal
- CNC machined 3/8” thick mounting flanges branded with Momentum Performance logo
- Factory O2 sensor bung locations
- We also have THREE Momentum Performance 350Z Turbo kits and ONE G35 kit. These will only be sold as a package deal to be installed at National Speed. $7,399 Installed and Tuned! Add $200 for an automatic Z.
Momentum Performance inventory for Cheap! Turbo Kits/Headers/Exhaust-mbhuk.jpg
Momentum Performance inventory for Cheap! Turbo Kits/Headers/Exhaust-uz8by.jpg
Momentum Performance inventory for Cheap! Turbo Kits/Headers/Exhaust-p3a7s.jpg
The Momentum Performance Single Turbo Kit is capable of producing between 400 WHP (stock motor) and 600 WHP (fully built motor). Two years and 25,000 miles of on-track testing have helped Momentum to develop on of the most durable and highest performing turbo kits on the market.
Reliability is assured through the use of the highest quality proprietary components, such as TIG welded,CNC mandrel bent piping, as well as partnerships with leading aftermarket manufacturers Garret, Tial, Deatschwerks, UpRev and Walbro. The kit’s high end design and components also ensure that it offers a smooth and easy installation process and looks great under the hood – important hallmarks of the “Push Forward” philosophy.
FEATURES
• Garrett GT35R with TiAL 1.03 A/R stainless v-band housing
• Intercooler: Custom high fin density bar and plate (9” x 22” x 3.25”)
• Wastegate: TiAL MV-R
• Blow-off-valve: TiAL Q 50mm
• Downpipe: 3″ 304 stainless with spare O2 bung for wideband installation
• Up-pipe: 2 1/4” 304 stainless
• Intake/Charge Piping: 3″ 6061 Aluminum with an integrated billet MAF housing
• Injectors: DeatschWerks 600cc plug & play (no adapter harness or spacers needed)
• Fuel Pump: Walbro 255 LPH drop in fitment
• Tune: UpRev flash package and basemap (no removing or mailing out your ECU.)
ADVANTAGES
• Coolant Surge Tank: Custom aluminum surge tank
• Supplied with one step colder NGK spark plugs(LFR6A-11) and a K&N Air Filter (5″ x 7″)
• All the necessary hardware, couplers and clamps along with detailed installation instructions
• Polished or optional Powder Coated intercooler and intake tubing (black or gray wrinkle powder coating)
• Polished or optional Ceramic coated exhaust tubing
We also have THREE cat-delete Y-pipes and ONE catted Y-pipe. Only $400 for Cat-less and $550 for one the catted!
Momentum Performance inventory for Cheap! Turbo Kits/Headers/Exhaust-5it8c.jpg
Momentum Performance inventory for Cheap! Turbo Kits/Headers/Exhaust-kjltu.jpg
The Momentum Performance Y-Pipe is a true track-oriented product specifically designed for hardcore racers seeking to “Push Forward” past the limits of their vehicle’s stock exhaust system.
By deleting the factory catalytic converters and replacing them with the Momentum Performance Y-Pipe not only are the multiple welds and seams of the factory exhaust system eliminated, but important weight savings over stock are also introduced. The Momentum Y-Pipe’s integrated test pipes offer a shallower angle than products offered by many of our competitors and are manufactured out of TIG welded, mandrel bent 304 stainless steel for the ultimate in strength and corrosion protection. The Y-Pipe reduces heat, flow matches exhaust gases for more power production and improves engine breathing.
FEATURES
• 2 1/4” primaries to one 3” secondary
• TIG welded construction
• Mandrel bends for optimal airflow
• 16 gauge 304 stainless steel
ADVANTAGES
• 3/8” stainless steel flanges
• Lightweight construction
Check out some previous Momentum Performance Turbo Kit installs we have done at the shop:
Tim's 2003 Nissan 350Z - Turbocharged.
Jermaine's 2004 Infiniti G35 - Turbocharged.
Darwin's 2003 Infiniti G35 - Turbocharged.
Shipping cost is not reflected in price. Call us at (910)332-5901 for any information!
Old Jun 5, 2012 | 07:45 AM
National Speed
You Z/G guys need go fast goodies!
Old Jun 6, 2012 | 09:54 AM
National Speed
We have stuff flying out the door right now! Get it while you can!
Old Jun 7, 2012 | 06:17 AM
National Speed
A couple Turbo Kits and sets of Headers have been sold. Our inventory won't last long at this rate!
Old Jun 8, 2012 | 06:09 AM
National Speed
It's Friday! Time to go fast.
Old Jun 8, 2012 | 06:32 AM
Johnnyone's Avatar
Johnnyone
"We also have THREE Momentum Performance 350Z Turbo kits and ONE G35 kit. These will only be sold as a package deal to be installed at National Speed."
is this for the HR engine also and where is National Speed?
Old Jun 8, 2012 | 09:28 AM
National Speed
Unfortunately this is not for the HR motor. National Speed is located in Wilmington, NC. If you can get your car here, we will cut you a deal!
Old Jun 9, 2012 | 12:39 PM
National Speed
Saturday Bump! Hope everyone is having a wonderful weekend.
Old Jun 11, 2012 | 06:38 AM
National Speed
Brighten up your Mondays (Or everyday!) with the awesome sound produced by Momentum Performance Headers/Exhaust! If you are feeling especially froggy, step up to the Turbo Kit and plaster a permanent grin on your face!
Old Jun 11, 2012 | 09:57 AM
ak350's Avatar
ak350
Too bad yall are 17 hrs away and i dont have the $, or else I'd be all over this.
Old Jun 11, 2012 | 10:17 AM
National Speed
It's indeed a good deal for Z/G enthusiasts. Momentum manufactured top quality parts and these are selling for a great price. Who knows, whenever you get some more cash flow, we may have some stuff still available! Any of the parts minus the turbo kit, can be shipped to wherever you live.
Thanks for the interest and happy motoring!
Old Jun 11, 2012 | 12:34 PM
Johnnyone's Avatar
Johnnyone
any dyno charts on the headers on a HR?
Old Jun 11, 2012 | 12:56 PM
ak350's Avatar
ak350
Think headers were only 03-05.......but I could be wrong.
ak350's Avatar
ak350
Heck ya its a deal. Lol, 7k of cash flow would be nice right about now.
Old Jun 12, 2012 | 06:29 AM
National Speed
Momentum Performance headers are for the 03-06 Only. There was no option for the HR Motor. The turbo kit fitment is the same way, as the HR uses dual throttle bodies and the Non-HR is singular.
03-06. Close enough!
We'll hold on to these as long as we can, but no promises, haha.
Old Jun 13, 2012 | 06:32 AM
National Speed
Daily Bump
Old Jun 14, 2012 | 06:33 AM
National Speed
Morning everybody. Get your morning wake-up with a new exhaust!
Old Jun 14, 2012 | 06:45 AM
DankZ07's Avatar
DankZ07
hr ftl...
Old Jun 15, 2012 | 06:17 AM
National Speed
Happy Friday, Everyone! Get your boost on!
Old Jun 18, 2012 | 05:26 AM
National Speed
Get your week started off right with some boost!
