FS: OEM VQ engine parts, plus aftermarket, Crawford V4 plenum
Old Jun 18, 2012 | 07:08 PM
konrad's Avatar
konrad
Default OEM VQ engine parts, plus aftermarket, Crawford V4 plenum
I am cleaning up my basement in prep for renovations. Here is a few parts I wont be using. I am willing to ship. I am located in zipcode 10306 NY if you want to check shipping
I am willing to take reasonable offers
05 REVUP heads 20k miles, with cam caps, OEM springs, front cam caps, $200 plus shipping
05 REVUP cams 20k miles $150 plus shipping or best offer
OEM crank, spun 2 main bearings , can be ground with over sized bearings $100 plus shipping
REVUP exhaust cam gears $80 plus shipping or $50 each plus shipping ( these are $450 each at the dealer)
Intake cam gears I have 4 of them, $80 for two or $50 each plus shipping
front cam caps $50 plus shipping ( I have an extra set)
lower runners $50 plus shipping
revup lower collector $75 plus shipping
rear timing cover $75 plus shipping
Valve covers $100 plus shipping these are painted metallic red with metallic clear cote
non rev up exhaust gears $50 both or $25 each plus shipping. also have the bolts
36 row oil cooler, this is TRU-Cool 36 Row oil cooler, AN-8 SS hoses, with Mocal Tstatic plate, mocal fittings selling only as a package $250 plus shipping
Non Tstatic sandwitch plate with AN-8 fitting. not sure of the brand $50 plus shipping
Megan Poly engine mounts 3k miles on them $100 plus shipping ( pic shows one because the other one is still attached to the cross member I have to take it out ) these are stiffer then OEM I went with IP solid mounts
350z shifter trim with climate controller ( there are 3 small scratches on the bottom, can be seen in the pic) $75 plus shipping
Old Oct 26, 2012 | 06:01 AM
konrad's Avatar
konrad
Bump. Exhaust cam gears sold
Old Oct 28, 2012 | 03:00 PM
Infiniti25's Avatar
Infiniti25
Do you still have the lower collector
Old Oct 29, 2012 | 11:00 AM
konrad's Avatar
konrad
Yes I do,
Old Nov 22, 2012 | 10:29 AM
konrad's Avatar
konrad
Default Crawford V4 plenum
Crawford v4 plenum. $150
Old Jan 10, 2013 | 10:56 PM
Boots patrol's Avatar
Boots patrol
Still got the oil cooler?
Old Jan 11, 2013 | 12:21 PM
Wasso's Avatar
Wasso
PM sent on the Valve covers
Old Jan 11, 2013 | 09:17 PM
dorrifto's Avatar
dorrifto
Do you have the rev-up throttle body?
Old Jan 14, 2013 | 05:37 AM
konrad's Avatar
konrad
No oil cooler and no throttle body
Old Jan 16, 2013 | 01:10 PM
6mtg's Avatar
6mtg
Is the lower plenum still available
BEBO'S ZEE
Jun 7, 2016 07:48 AM
_koubie_
Sep 20, 2015 06:34 PM
