FS: OEM replacement parts & some aftermarket
Old Sep 3, 2012 | 06:23 AM
agallardo's Avatar
agallardo
Default OEM replacement parts & some aftermarket
Hey guys, I have gone through a couple builds and had a spare motor as well that I broke down. So I have lots or replacement parts. I also have the hardware for most of the parts, along with timing components that are not shown in the pics, like sprockets, chains, guides, etc. Anyway here are the parts I have:
(Prices do not include shipping or fees)
Passenger Side rear axle: $30
Coil packs (x6): $30 each (ONE SET SOLD!)
Stock Motor mounts: $40
FP Solid Motor mounts: SOLD
Stock Fans: $50
Flex-a-lite fans: $100
Fan shroud: $20
Koyo Racing Radiator: $50
GT SPec rear brace: SOLD
Upper Oil pans (x2): $20 each
Valve covers: $20 each
Stock Heads: $200
Front Timing covers (x2): $40 each
Rear Timing covers (x2): $40 each
Lower plenum (x5): $50 each
Upper plenum: $50
Throttle body (x2): $40 each
Lower plenum divider (x2): $30 each
Oem Crankshaft: SOLD!
Oem diff cover: $30
EVO 8/9 oil cooler: $50
5 EAGLE rods: $60 each
95.5mm Arias pistons: $200
96mm Arias pistons: $200
Rear coolant pipes (x2): $40
Wheel bearing: $50
Oem Starter: $50
Oem Crankshaft pulley (x2): $30 each
Gaskets
-Head gaskets: $50 each
-throttle body gaskets: $10 each
-rear coolant block-off gasket: $10 each
-plenum gasket: $15
-valve stem seals: $20 a set
PM me if interested...
Attached Thumbnails OEM replacement parts & some aftermarket-2-raidiators-and-2-fans-and-fan-shroud.jpg   OEM replacement parts & some aftermarket-crank-shaft-and-diff-cover-and-divider-x2-and-upper-plenum-and-front-and-rear-timing-covers.jpg   OEM replacement parts & some aftermarket-12-cold-packs-2-stock-motor-mounts-and-2-solid-motor-mounts.jpg   OEM replacement parts & some aftermarket-starter-gt-spec-brace-2-oil-pans-2-crank-pulleys.jpg   OEM replacement parts & some aftermarket-rear-and-front-timing-cover-2-heads-2-sets-of-valve-covers-5-lowers-plenums.jpg
Old Sep 3, 2012 | 12:13 PM
cimotorsports's Avatar
cimotorsports
Pm sent!
Old Sep 3, 2012 | 12:35 PM
Wilhelm's Avatar
Wilhelm
Hey hey hey dibs on a few things lol
Old Sep 3, 2012 | 05:39 PM
agallardo's Avatar
agallardo
PMs sent...
Old Sep 3, 2012 | 08:45 PM
Wilhelm's Avatar
Wilhelm
Payment sent for FP Motor Mounts and GT Spec Rear Brace. Somebody help him out with the other stuff.
Old Sep 7, 2012 | 03:01 AM
agallardo's Avatar
agallardo
Bump
Old Sep 16, 2012 | 03:18 PM
agallardo's Avatar
agallardo
BUMP
Old Sep 19, 2012 | 03:37 AM
agallardo's Avatar
agallardo
Bump
Old Sep 22, 2012 | 01:11 PM
z2envy's Avatar
z2envy
pm price for both left and right side valve covers to 33967
Old Sep 26, 2012 | 06:46 PM
agallardo's Avatar
agallardo
BUMP
Old Sep 28, 2012 | 05:59 AM
agallardo's Avatar
agallardo
Bump
Old Sep 29, 2012 | 12:42 PM
cg04350z's Avatar
cg04350z
is the upper oil pan for a DE non rev up if so how much for it shipped to 79907
Old Sep 30, 2012 | 04:10 AM
agallardo's Avatar
agallardo
Yes it is... For DE
Old Oct 3, 2012 | 06:15 AM
agallardo's Avatar
agallardo
Bump
Old Oct 3, 2012 | 07:58 AM
laurentj23's Avatar
laurentj23
Koyo radiator shipped to 37415
Old Oct 6, 2012 | 05:12 PM
agallardo's Avatar
agallardo
BUMP
Old Oct 8, 2012 | 08:31 PM
USMChris's Avatar
USMChris
How are the seals on the valve covers? Do they leak oil on the spark plugs?
Old Oct 11, 2012 | 03:35 AM
laxplaya1385's Avatar
laxplaya1385
Will the coils fit on a 5th gen maxima?
Old Oct 11, 2012 | 07:37 AM
neko06's Avatar
neko06
PM'd
Old Oct 11, 2012 | 11:39 AM
agallardo's Avatar
agallardo
Yes they should
