FS: Built motor @ $2k!
Old Dec 27, 2012 | 05:21 AM
rcdash's Avatar
rcdash
Arrow Built motor @ $1500 !!!
SOLD
Upgrading my motor at Dynosty with a brand new long block. Old built Forged S1 motor is now for sale. Great motor for 600 whp. 25k miles on motor with Eagle rods, Cosworth bearings, Arias ED pistons, L19 studs, HKS headgasket, JWT S2 cams and valve springs, stock valves.
The motor is running fine and making power, a compression test 3 months ago was all around 132 but this is where it stands as of December:
Compression test: (cold,wot,w/plugs,1-6:139,132,112,138,130,128)
#3 spark plug has oil/buildup
Also, see attached. There is evidence of fuel in the oil - maybe washing out cylinder 3 and pretty clear evidence of piston wear (never seen before on UOA). Might have had a fuel injector issue for the past couple months. The motor will require a rebuild to get it back perfect with re-bore of cylinders, new matching pistons and new HG. Rods, L19 studs, crank, cams, springs should all be fine. I am uncertain if we experienced spark blow out on cylinder three causing the fluctuating power at high rpms or if that is completely unrelated. I have asked Hal to swap out the injectors or get them tested before putting in the new motor.
Motor will still be a great deal as a core. It is also running perfectly fine and for a 500 whp car, might be just fine for a good while with a solid tune before there is any significant loss of power.
PM me with any questions. $1500 obo. + shipping via crate directly from Dynosty.
PS. Ignore the turbo kit components on there - that doesn't come with the motor!
File Type: pdf
Old Dec 28, 2012 | 04:45 AM
rcdash's Avatar
rcdash
Bump - get a built motor for price of a stock core with many high quality parts. Pistons and headgasket and she's good to go. Shoot me a reasonable offer via PM.
Old Dec 30, 2012 | 09:11 AM
rcdash's Avatar
rcdash
Dyno from 3 months ago on this motor.
Even if FI is not your thing, put in high compression pistons and you'll have a great NA motor at a fraction of the usual cost.
Old Dec 31, 2012 | 11:52 PM
V1P's Avatar
V1P
i am interested, definitely going to get back to you as soon as i am a bit less tired and sober tomorrow .... if i forget .. please get a hold of me at kyrillv@gmail.com
Old Jan 7, 2013 | 06:00 AM
rcdash's Avatar
rcdash
E-mail sent.
Old Jan 8, 2013 | 06:39 AM
rcdash's Avatar
rcdash
BUMP $1500 + shipping!!! The L19 studs, cams, and rods alone are worth that, not to mention the rest of the block, crank etc.!!
Old Jan 8, 2013 | 07:01 AM
meanz's Avatar
meanz
pmed
Old Jan 8, 2013 | 07:30 AM
06z33's Avatar
06z33
pm'ed
Old Jan 8, 2013 | 09:09 AM
meanz's Avatar
meanz
and one more pm for you!
Old Jan 8, 2013 | 07:15 PM
Z_rican's Avatar
Z_rican
PM sent sir
Old Jan 8, 2013 | 09:58 PM
meanz's Avatar
meanz
glws
Old Jan 9, 2013 | 06:01 AM
rcdash's Avatar
rcdash
Ok, sale pending!
Old Jan 9, 2013 | 04:30 PM
rcdash's Avatar
rcdash
Fell through ... still available.
Old Jan 10, 2013 | 10:26 AM
rcdash's Avatar
rcdash
Ok, sale pending, again.
Old Jan 10, 2013 | 03:33 PM
homeboynyc's Avatar
homeboynyc
Is this still available? I'm local
Old Jan 13, 2013 | 07:30 PM
fkakarZ's Avatar
fkakarZ
Old Jan 14, 2013 | 05:48 AM
Max Streets's Avatar
Max Streets
are selling thosefuel rails cjm
Old Jan 14, 2013 | 09:38 PM
sparticus213's Avatar
sparticus213
im very interested get a hold of me shipping would be too 84338 ut
Old Jan 19, 2013 | 01:44 PM
zphein03's Avatar
zphein03
is this still available
Old Jan 22, 2013 | 05:48 PM
Z_rican's Avatar
Z_rican
Sold to me.
Fixxxercask
Nov 9, 2015 11:10 AM
