350Z Air Bag Installation
Old Nov 29, 2004 | 06:49 PM
stormcntr2000's Avatar
stormcntr2000
Default 350Z Air Bag Installation
Does anyone have information on intallation of front air bags on
2003 350Z ??? I have the pass side out and ready to reinstall
Batts disconected --- Fixin to pull Drivers side --- Want to make
sure that reinstallation is correct in order to avoid a broken face--
Thanx Guys --- I own the New Berlin Garage --But dont have the
service manual ---This is my car ----In a rush
Old Nov 29, 2004 | 11:43 PM
ZZZealous007's Avatar
ZZZealous007
Personally i wouldnt mess with the airbag system, esp if your in a rush. Just take it to the dealer and have them sort it out. Its not worth doing something like airbagson your own. Too much risk involved in my opinion.
Old Nov 30, 2004 | 07:41 PM
pearlwhitez's Avatar
pearlwhitez
I'll share some insight. Make sure to replace all sensors that were damaged. The Airbag Module must be replaced at all costs. Check the clockspring, if everything is okay, put the bag in. Drop it by the dealer for them to check the computer for codes. Then you'll be all set
Old Dec 1, 2004 | 03:50 AM
stormcntr2000
Thanks so much for the reply --I had bought the clock spring ,,but not the sensors nor module ---Was not sure of location of sensors but believe module is under console--My diagnostic machine is updated to 2003 asian so the coding and clearing I can do --There is a CD rom shop manual available for 220.00 that is soon to be a must buy---Im on the road now --everything is perfect cept the A/B installation although Pass. Side A/B is installed with no hookups at this time---It was a soft hit --just a little plastic damage and cond --Rad --Small hood dent ---Replaced with a Kaminari-New paint turned out awesome---Thanks again !!!!!!
etkms
Jun 19, 2022 06:30 PM
NiLL
Nov 29, 2021 02:26 PM
Vigman
Nov 17, 2015 04:34 AM
