Winter Storage Questions?? I know we went over this b4 but....
Old Dec 16, 2004 | 09:21 AM
SixRB6's Avatar
SixRB6
Default Winter Storage Questions?? I know we went over this b4 but....
I am putting the Z to sleep on Sunday cuz it is going to snow here in the Northeast
I keep hearing all these different ways to store the Z in the winter.. Can you guyz give me the best way and what I need to do when I put her away!? It will be in a garage with a cement floor that has not bee treated. The reason I say that is because i read somewhere that I should put a blanket on the floor then drive the car on it?? Is that right?
I also read I should park it on Styrofoam??? whats up guys I need help fast!!!!!!
Old Dec 16, 2004 | 12:16 PM
Mapleleaf's Avatar
Mapleleaf
It depends on if you are going to drive it sometimes over the winter months when the weather is good .This will be the 3 winter I seen and when it is dry I bring it out for a good boot around town , other than that make sure you have a full tank , I keep a automatic battery charger hooked, up have your tires inflated properly, clean it cover her and that should be good.
My garage is cement as well untreated.
Old Dec 16, 2004 | 04:32 PM
cbrflyer919's Avatar
cbrflyer919
When I used to Store my motorcycle I would park on cardboard. It is supposed to keep the tires from deteriorating, at least thats what I have read. Also, if you keep gas in it, you might consider a fuel stabilizer depending on how long you are going to not run the engine.
Old Dec 16, 2004 | 05:00 PM
bgwillyis300's Avatar
bgwillyis300
yep when you put in storage i would suggest putting about half tank of gas in it then running to walmart and get a thing of "Fuel-stabill" Its red. and put that in so when you do start the car it isnt eating rotten fuel.
Old Dec 16, 2004 | 11:28 PM
ZIABLO's Avatar
ZIABLO
I am Batman
https://my350z.com/forum/showthread....threadid=39048
Old Dec 17, 2004 | 05:14 AM
mdacko's Avatar
mdacko
definetely put something under your tires - plastic/cardboard/etc. if not, the cement will pull moisture out of the tires and cause them to deteriorate - or something like that.
Old Dec 17, 2004 | 06:18 AM
SixRB6's Avatar
SixRB6
Thanks EnthuZiastDrive for the thread
beezee
Nov 4, 2011 02:50 PM
nlsqba
Mar 14, 2005 04:33 PM
uplz4588
Oct 4, 2004 01:05 PM
