how do you get a 10gauge wire from cabin to battery?!?!
Old Dec 26, 2004 | 01:10 PM
rummya87's Avatar
rummya87
Default how do you get a 10gauge wire from cabin to battery?!?!
i need to get a 10 gauge wire from the cabin to the battery to run a fuse box ... the 10gauge wire will be dedicated hooked to the positive terminal and any way to get it into the cabin will work ... but preferably i want it to go through the driver's side ... thanks in advance!
-Rami
Old Jan 20, 2005 | 11:35 AM
Jun's Avatar
Jun
there are a bunch of wires that come from the outside to the inside of the cabin. It's covered with black electric tape, you can follow it from the inside. It's just a matter of seeing from the outside where it pokes out.
Old Jan 20, 2005 | 01:03 PM
ezee's Avatar
ezee
A bundle of wires runs through a rubber grommet that is right behind the battery, you'll need to remove the plastic parts from around the batter to reach it. Carefully cut a small hole in the grommet and push the wire into the cabin, then you can see the end from the passenger footwell and pull it in.
Old Jan 20, 2005 | 02:02 PM
Srivero297's Avatar
Srivero297
or you can use something rigid (a straightened metal coat hanger works well) and get it through the hole all the way into the footwell first, then tape the wire to the end of the coat hanger and snake it through.
Old Jan 20, 2005 | 02:53 PM
willpower's Avatar
willpower
There is a harness that runs from the left side into the cabin if you take the cover of you can see it....but its pretty tight in there your gonna have to take the cowle screen off to get at it....
Old Jan 20, 2005 | 04:01 PM
rummya87's Avatar
rummya87
found it! thanks guys ... i finished a huge interior LED lighting project ... theme is Red vs Blue ... everyone who's seen it says it looks good but ill post pics in not too long
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
