OEM spoiler?
Old Jan 15, 2005 | 09:16 PM
RedShft's Avatar
RedShft
Default OEM spoiler?
is the OEM spoiler mounted by simple adhesive strips or is it actually drilled into the hatch? if its drilled...do other aftermarket manufacterers use the same mounting points? thanks.
Old Jan 16, 2005 | 08:01 PM
RedShft's Avatar
RedShft
TTT...someone has to know
Old Jan 17, 2005 | 07:35 AM
04ECSTAZ's Avatar
04ECSTAZ
Default Re: OEM spoiler?
BOTH. Mine didn't come with a spoiler, so I added the factory one. It has a piece of 3M double sided tape all the way around the spoiler, but you also need to drill 4 holes into your hatch to secure it(some say the tape isn't enough to hold it, but I didn't want to find out the hard way!) but if your car came equipped fromt he factory with the spoiler, Im sure it has the drill holes.
Not sure if these holes are used by other spoiler manufactures...
we need some input from you guys with the aftermarket spoilers here!!!
The holes I had to drill though are HUGE...2 of the 4 holes are almost the exact same size as a quarter...
Hope this helps ya RedShft
Old Jan 17, 2005 | 08:54 AM
RedShft's Avatar
RedShft
yes, this does help man....thanks. now i'd just like to know what aftermarket companies use the same holes.
Old Jan 20, 2005 | 05:39 AM
Jun's Avatar
Jun
since you are going to have it painted an all, you might as well just patch the holes.
i'm glad i didn't get the factory spoiler. My trunk is holeless :P
Old Jan 20, 2005 | 02:50 PM
rich harris's Avatar
rich harris
You can use any spoiler from Japan, they will fit the holes from factory....For example ...my car came with the factory one....I replaced it with the Vielside V3 .....the holes lined up perfectly.....
Old Jan 20, 2005 | 04:39 PM
RedShft's Avatar
RedShft
well mine is too, but i was considering getting an OEM spoiler for the time being...until i decided on exactly which aftermarket one i wanted to go with.
sweet, this is good to know since ive been thinking about either the Veilside V1 or V2 spoiler.
Old Jan 21, 2005 | 07:14 AM
04ECSTAZ's Avatar
04ECSTAZ
Factory spoilers come pre-painted from Nissan...also most people don't have the choice, as their Z's already came from the factory with the OEM spoilers(and holes ).
glad to hear though that a lot of the aftermarket spoilers utilize the same holes as the OEM does for us that have the OEM.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
