debadging the Z questions...
Old Jan 23, 2005 | 08:40 PM
HarvesterUT's Avatar
HarvesterUT
Default debadging the Z questions...
i want to take off the front and rear nissan burgers to put some custom stuff there. are there holes under the rear badge on an 05 model or not? i assume the front has no holes. also, what is the best method for taking off the emblems? prying it carefully and then using goo-gone on the adhesive?
TIA
Harv
Old Jan 24, 2005 | 03:15 AM
35oZephyR's Avatar
35oZephyR
Use a heatgun until the adhesive gets a little soft.
Use dental floss to cut through the gum.
Wrap a flat head screwdriver with a grocery bag so it won't scratch your car.
Now slowly lift the emblem up all around with the flathead so you can access the gum easier with the floss.
Clean residue with goo-gone.
Old Feb 12, 2005 | 06:42 AM
sluggoZ's Avatar
sluggoZ
In the front, the coupe and roadsters have two "tit prongs"' sticking out. In the rear the coupe has two holes and the roadster has none.
Go with the instructions of the previous poster...I used fishing wire and I "sawed" & pulled upwards each time, do not pull side to side. The key is take your time. lol
aznmojo
350Z Roadster
44
Nov 2, 2005 12:15 PM
Vamos_Rafael
Aug 15, 2005 11:28 PM
jkoc
Jun 4, 2005 07:24 AM
theSmoothDome
350Z Roadster
47
May 20, 2004 11:49 AM
leykias
May 2, 2004 12:27 AM
