How do you reaplace parking BULB?
Old Feb 1, 2005 | 01:16 PM
pureZness's Avatar
pureZness
Default How do you reaplace parking BULB?
how do you do it?
there's no way that i can stick my hand in it?
i gotta replace the stock yellow parking bulb to Ares's Bulb.
please help! thanks!!!
Old Feb 1, 2005 | 02:57 PM
myz8a4re's Avatar
myz8a4re
remove all the screws that hold the plastic inner fender lining on. then pull the lining off. then you have full access to the back of the headlight. might take a bit of time your 1st time but its not that bad.....best of luck!
-justin
Old Feb 1, 2005 | 03:49 PM
pureZness's Avatar
pureZness
after all that, when i put the inner fender lining back on. it doesnt get lose or nothing?
Old Feb 1, 2005 | 03:51 PM
myz8a4re's Avatar
myz8a4re
no problems here.......
-justin
Old Feb 2, 2005 | 11:22 AM
juhko's Avatar
juhko
Why do you think that the fender lining would get loose?
Old Feb 2, 2005 | 02:38 PM
Faluzure's Avatar
Faluzure
Any chances of pics?
Old Feb 2, 2005 | 03:41 PM
Jun's Avatar
Jun
no need to remove the screws. Just turn the wheel all the way to the right fi you are doing the left side and vice versa. The just pull the fender lining from the bottom out, all the way until where the bumper meets the fender.
That's it.
Old Feb 2, 2005 | 05:07 PM
Faluzure's Avatar
Faluzure
Seems like I'd damage something though...
Old Feb 3, 2005 | 08:53 AM
D@ActiveTuning's Avatar
D@ActiveTuning
It's just a couple plastic poppers and a couple screws. When you are done, pop the poppers back in, and screw the screws back in, no harm done.
Old Feb 4, 2005 | 05:21 AM
ares's Avatar
ares
Veteran
2 screws on the edge of the fender and wheel well. 3 fasteners starting at the top and running down the inside of the wheel well in a line.
then push up on the wheel well, and push in. itll go eventually, its not difficult to move, but you have to get the right motion; when it goes youll say "ohhhh".
from there, your staring at the light socket, twist and pull out,
Old Feb 4, 2005 | 12:34 PM
Faluzure's Avatar
Faluzure
Thanks! Replying for bookmarking purposes.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
ablaine
Nov 29, 2016 10:13 AM
hardwood66
Sep 8, 2015 04:31 AM
