Clear Corners
Old Apr 6, 2005 | 08:02 AM
sprazyo's Avatar
sprazyo
Default Clear Corners
I am new to the Z. How do I get to the Blinkers so I can put some clear corners in. Also...where can get some clear corners. Also...where can i get some red vinyl lay-overs for my reverse lights.
Thanks in advance,
Mike
Old Apr 6, 2005 | 08:05 AM
sprazyo's Avatar
sprazyo
Found the clear corners. Just need to know how to get them on. Do I have to take off the whole bumper?
Old Apr 7, 2005 | 05:51 AM
Chicken's Avatar
Chicken
I don't know if you *have* to, however it would certainly be easier if you did. Two screws each side, very quick to replace. You could probably get by with just taking enough of the bumper off to access the areas.
Old Apr 7, 2005 | 07:13 AM
drifter23's Avatar
drifter23
Getting to the headlight blinkers do not require taking the front bumper off. There is a thread in here that has detailed instructions on changing bulbs.
Here is a thread on Changing the bulbs that Ares wrote:
https://my350z.com/forum/showthread....threadid=55808
Old Apr 7, 2005 | 09:54 AM
spdu4ia's Avatar
spdu4ia
to do the clear corners take off your bumper... your nuckles will thank you.
Old Apr 7, 2005 | 11:12 PM
ares's Avatar
ares
Veteran
the process to take off the bumper will expose some other potential venues... if you at any time during the process see that you can get to it; go for it.
I jack up the car; remove the wheel wells and thats it. others go farther and remove the skidplate, and then there are those that go all the way and remove the bumper. you have to remove all of these in that order anyway; after each step see if you can get your hand in there; with a VERY short screwdriver(<3") you can do it after only the wheel wells.
Sleeper_Z
Sep 30, 2015 10:25 AM
