tint not sticking over bumps on windows
Old Apr 10, 2005 | 09:09 AM
jukljs's Avatar
jukljs
Default tint not sticking over bumps on windows
Hello, i had my 350z tinted last week (its the first car i've ever had tinted) and i noticed a few days later that on the two little windows and the rear window the tint doesn't seem to be sticking over the little bumps. I am wondering if this is normal with the 350z or should i take it back and get it redone. Here are a couple of pics to try to show what I am talking about. You can see how the tint not sticking creates a white line around the window. I can press on the tint on top of the little bumps with my finger and it will stick for a few seconds then come off again.
Attached Thumbnails tint not sticking over bumps on windows-tint002.jpg   tint not sticking over bumps on windows-tint003.jpg   tint not sticking over bumps on windows-tint001.jpg
Old Apr 10, 2005 | 09:30 AM
NJ_FairladyZ's Avatar
NJ_FairladyZ
Those bumps are normal -- i just got my Z tinted also. The place that did the tint told me to come back in about 30days and they would take care of the white outline once the tint finishes curing.
I would see if you could take ur Z back to the place that tinted your windows and have them finish what they started.
BTW, how much did you pay for your tint??
I paid 200... 5% rear windows and 15% on the driver and passenger windows
Old Apr 10, 2005 | 09:36 AM
jukljs's Avatar
jukljs
i paid $200 canadian. i live in toronto. i have 20% all around except the front.
thanks for your reply, i'll give the tint place a call during the week.
Old Apr 10, 2005 | 09:50 AM
harrieyu's Avatar
harrieyu
173$ 20& all around...lifetime warranty
but the thing with our car is that there is a feature that automatically moves the windows up and down to air tight lock the car. in order for the tints to cure correctly you should nto move the windows for like 2 days or so. i have really MINOR bumps that i can't really see becasue of this feature. i called nissan and theres no wayt to turn it off unless you open the door, disconnect the battery, then close the door but then your windows will be slightly lowered. the bumps are not noticable on my car unless u look for them so i dont mind.
Old Apr 10, 2005 | 10:38 AM
Mantis3024's Avatar
Mantis3024
You cant tint over the black dots. Well, you can but the film won't stick and it'll start to bubble. If you ask me, the shop did a pretty good job. If you want to cover it up, the best way to go is to get black vinyl and tape over it yourself.
Old Apr 10, 2005 | 10:46 AM
AmateuRN's Avatar
AmateuRN
Yeah. 05 Stangs have this problem bodly. Come of them sand down the dots and then tint it with no problems. OR, a peice of black vinyl over the top part of the windsheild works also - its not noticable from outside and matches the darker tint.
Old Apr 10, 2005 | 10:52 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
When the local tint shop did my parents Durango they used Elmers glue on the part with the little bumps. Worked really good, totally clear and it sticks just like the rest of it.
Old Apr 10, 2005 | 10:58 AM
ANXIOUZ's Avatar
ANXIOUZ
When I had mine done, they said to roll the back of your thumb against the tint to push it back against the dots. I didn't bother though and my tint looks great.
But like someone said, the auto-rolldown of the windows can cause the tip of your windows to bubble. Keep an eye out for that. I have some VERY minor imperfections from this.
Old Apr 10, 2005 | 01:39 PM
2 low Z's Avatar
2 low Z
Is there a fuse you can pull to disable the auto-rolldown feature?
Old Apr 10, 2005 | 02:41 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
touch the windows down just a bit and it wont know to do it
Old Apr 10, 2005 | 03:48 PM
2 low Z's Avatar
2 low Z
thanks, I'll give it a shot.
Old Apr 21, 2005 | 01:17 PM
bxd164's Avatar
bxd164
you can tint over the bumps....but you have to heat up the glass from the OUTSIDE with either a torch or a heat gun....I just tinted my windows last weekend!
Siqcology
Sep 18, 2019 01:45 PM
3vilbunny
Jul 18, 2017 05:10 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
AP350z223
Sep 8, 2015 04:38 PM
