How to Exchange Hi Beam Lamps
Old Jun 2, 2005 | 10:26 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Default How to Exchange Hi Beam Lamps
I didn't see a how to on this simple modification so I thought I'd contribute one.
The HID projector bulbs on the Z are plenty bright enough but I found the conventional 55 W Halgen hi beams to be a bit yellow compared to the HID's and a bit under powered. After shopping around I picked up a set of SuperBeam EX 4500K lamps that run 100 Watts from autohalogen.com for $34.75 a pair. The bulb is an H7 and the total change out takes about as much time as changing a tire plus a few more minutes.
Here's a picture showing the difference beween the two lamps.
And a close up.
Now how to do the procedure. First remove the tire to expose the front plastic liner. You'll need to remove three plastic clips using a small flat blade screw driver. You simply pry out the center pin and pull the whole assemble out. There is only one screw that you'll need to remove. I removed two more now at the bottom of the liner to get better pictures. Note: I've got the rear splash panel off to install some sound deadening materal, you do not have to remove this panel for the headlight work.
Pulling the liner down and out of the way you'll expose the head lights - the projector and hi beam are under the light gray plastic disk.
Rotate this cup clockwise about 1 inch and the disk should come lose. A rubber "O" ring protects the lamps from water thrown from the wheel.
With the gray plastic disk removed you can get to the hi beam lamp. It's held in place with a spring clip that has one leg sticking out. Push this leg down and then rotate it upwards a bit to unlatch it from it's keeper. At this time I put clean cotton gloves on to protect both the old and new bulbs.
Here's the stock and superbeam bulb side-by-side along with the work gloves and the inside of the gray plastic dish showing the "O" ring. I'm keeping the old bulbs as a spare in case I blow one of the replacements.
The blue of the light is a bit different and looks good on my super black and would probably work on a Daytona blue as well.
The 100W lights are a bit brighter and they cast a cleaner whiter light than the stock ones.
Paul
Old Jun 2, 2005 | 11:51 PM
NOBI's Avatar
NOBI
good write up, ive been thinking about doing this, but i cant get by the blue bulbs in the housing. what do you forumites thing the best option would be? silver stars?
Old Jun 2, 2005 | 11:55 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Excellent write-up. This definitely has to be put under the "Tech & How-To" section.
Old Jun 6, 2005 | 10:08 AM
Jun's Avatar
Jun
Be careful with those blue bulbs. I've had past experience with the blue bulbs shattering, and getting stuck with the little blue glass pieces inside the headlight. Not those specifically, but the blue-colored glass bulbs in general.
Old Jun 6, 2005 | 05:35 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Yeah, I've seen Halogen bulbs as cheap as $7. All halogen bulbs are sensitive to the oil in your hands so you have to wear clean gloves when handling them. The oil will act as a hot spot and can cause the bulb to pop.
Old Jun 12, 2005 | 11:06 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
do you have the direct link to the product Paul?
Old Jun 18, 2005 | 01:23 AM
UrbanTacticZ's Avatar
UrbanTacticZ
isnt it bad to run 100watt bulbs? i know that on a lot of hondas, those guys have problems running 100watt bulbs and they tend to burn up the wires, since your running almost double what stock is?
iono just thought id mention it =)
looks better than stock, thats for sure haha
Old Jan 7, 2006 | 10:16 PM
jlvvega's Avatar
jlvvega
Unhappy
where are those pics!!!!!!!!!!
Old Jan 8, 2006 | 03:48 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Dang. It would be nice to be able to edit my post.
Old Jan 12, 2006 | 08:35 AM
Jun's Avatar
Jun
btw, both bulbs are halogen bulbs.
Pleask
Dec 21, 2021 03:17 PM
aboodi
Oct 28, 2015 02:07 PM
slaponte
South East
Feb 26, 2003 12:54 PM
VandyZ
Sep 22, 2002 06:55 PM
