More LED Pictures
Old Jun 11, 2005 | 08:18 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Default More LED Pictures
Parking lights WLED 6-LED white $3.64 each from www.superbrightleds.com from the looks of it you could fit the bigger 9 Led and possibly the large 15 LED wedge bulbs in there if the base fits the stock socket.
Just the parking lights:
With the projector lights on they disappear.
And an after dark picture:
I didn't take pictures with all the lights off as the stock and LED replacement lights are both white and rather invisible. Note the stock turn signals are still in place adding lots of yellow. Also the yellow sliver light wasn't changed out as it's behind the darn yellow strip anyway.
The parking lights are a bit dimmer but much more of a clean white color.
This thread will help you get to the headlights if you're so inclined: https://my350z.com/forum/exterior-and-interior/125887-how-to-exchange-hi-beam-lamps.html
Old Jun 11, 2005 | 08:54 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
And the interior overhead lights:
A bit of help from the blue foot well lighting
Source: www.superbrightLEDs.com part 3022 4-LED Festoon bulb white $2.84 each.
Old Jun 11, 2005 | 10:53 PM
nicolaycastro's Avatar
nicolaycastro
It looks great, thanks for sharing the pics, It gives good reference from stock to led.
One question though, how do you hold your Ipaq (plam) there?
Old Jun 12, 2005 | 06:39 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Actually that's a Garmin iQue navigation/Palm PDA. It's got the same navigation abilities of the fullsized Garmins and is also a portable PDA to boot.
I designed a custom built holder.
I started with some alumimun plate I had. I cut it to size and bent it into a "U" shape which clamps onto the cubby hole door. The back side is cut and bent a bit to fit the shape behind the door. The inside of the "U" is surounded with 1/16" thick rubber to protect the cubby door. The bottom of the "U" has it's outside covered with the fuzzy part of a velcro strip to protect the bottom of the cubby.
I took the bean bag of the iQue holder apart and ran the screws from the base through the "U" and bingo I'm done. The thing pops out in a few seconds to move it to the other car if need be.
Old Jun 12, 2005 | 07:15 AM
nicolaycastro
wow nice job, it sound a little difficult though, do you have close up pics?
Old Jun 12, 2005 | 07:23 PM
tMaCZLoVeR4LiFE's Avatar
tMaCZLoVeR4LiFE
is there a way to change our turn signal bulbs and rear brake lights to led bulbs? Would it be just as easy as a bulb swap?
Old Jun 12, 2005 | 07:35 PM
valdeztke's Avatar
valdeztke
Bulb number for the interal map lights and what website to order them ..
thanks!
Old Jun 14, 2005 | 08:31 AM
boma's Avatar
boma
https://my350z.com/forum/exterior-and-interior/125583-my-led-lighting.html
Old Jun 14, 2005 | 08:39 AM
Reggi914's Avatar
Reggi914
nice job, thanks for sharing!
Old Jun 14, 2005 | 09:39 AM
tMaCZLoVeR4LiFE
thanks....would it be better to use the white vs red LEDs behind the taillights so that it would be brighter...thanks
Old Jun 14, 2005 | 09:49 AM
Acree's Avatar
Acree
the general rule, for a colored lense, is use the same color of bulb. besides, with the current LED technology, red LEDs are usually brighter and cheaper than white LEDs. hope this helps.
Depravity
Oct 1, 2015 04:49 PM
