how to do your own dash?
Old Jun 20, 2005 | 07:31 AM
itsjoshufocker's Avatar
itsjoshufocker
Default how to do your own dash?
ive seen this done many times on the the site... what are the steps in order to do this? all the sanding.. wet sanding (what is it by the way), primer, painting, and all of that? i wanna get this done, but i dont have the money to get it done.. so this is kinda a do it yourself project for me. any help?
Old Jun 20, 2005 | 08:02 AM
Reggi914's Avatar
Reggi914
it takes a whole lot of work and a whole lot of time.
Old Jun 20, 2005 | 08:18 AM
itsjoshufocker
yeah i know that much... but what are the steps involved?
Old Jun 20, 2005 | 02:03 PM
B-Unit's Avatar
B-Unit
Do a search for wetsanding under this forum, i posted a complex writeup of how to do it, im too lazy to do it again. GL but unless youve done this type of stuff before, youll probably resort in taking it to a professional to get done one way or another.
Old Jun 20, 2005 | 11:27 PM
itsjoshufocker
haha got a link to it?
Old Jun 21, 2005 | 05:02 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I think he said to do a search
Old Jun 21, 2005 | 08:23 AM
itsjoshufocker
https://my350z.com/forum/showthread....ht=wet+sanding
wow this is quite a process... should be fun...
"Block sanding is very important cuz hands create grooves." what do you mean by this, bryan?
Old Jun 21, 2005 | 10:48 AM
B-Unit's Avatar
B-Unit
whenever you sand something down, if you use your hands, your fingers will naturally create waves in the surface due to your hand/fingers inability to create a completely flat surface, that is why you need to use a sanding block. You can purchase small sanding blocks at Lowes or any autobody store, just makes sure you get one that has a soft bottom instead of one that has a hard bottom.
Old Jun 21, 2005 | 01:30 PM
manny007's Avatar
manny007
At what PSI should you set your air compressor when applying your primer, base and clear coats.
Old Jun 21, 2005 | 01:35 PM
bixby's Avatar
bixby
25 psi will do.
Old Jun 21, 2005 | 02:09 PM
B-Unit's Avatar
B-Unit
Depends on the guns ur using, they should tell you but most hvlp guns function with around 20 psi at the cap. Make sure you get the spray uniform before. primer isnt that big a deal cuz its getting sanded down anyhow.
Workshop12
Mar 23, 2020 01:45 PM
jlb
Oct 15, 2017 05:10 AM
Vigman
Nov 17, 2015 04:34 AM
Daniel_dh
Sep 7, 2015 12:56 PM
