Seibon Hood - What is needed? How hard is fitting it?
Old Jun 29, 2005 | 11:23 AM
LaidbackRacr's Avatar
LaidbackRacr
Default Seibon Hood - What is needed? How hard is fitting it?
I just called Z-1 I am going to order Seibon TS or VT hood (not decided yet) and Adam told me it doesn't come with hardware. What hardware is needed? And where can I get it? Also Adam said install took him about 4 hours to fit right...why is this? How long did it take you
Old Jun 29, 2005 | 06:56 PM
kcobean's Avatar
kcobean
If you don't paint it, it should take you about 30 minutes to take the old hood off and put the Seibon on. The stock hood has studs that go through the hinge holes and attach with nuts, where the Seibon hood has threaded holes and bolts that screw in. Mine came with the bolts, and in my eyes, that qualifies as "hardware". The bolts were actually used to hold the wooden braces used for shipping on so you had a safe way to put the hood up on it's edge. I think you'll be fine.
As for fitment, I had to do some minor bending of the hinges, but it was minor and the hood fits perfectly. I'm not even using hood pins at this time because the hood latch locks just like stock (in some earlier models, the metal loop in the hood was a tad short, so it was always under stress).
I actually removed the old hood and installed this by myself. It's that easy.
Old Jun 29, 2005 | 07:28 PM
Nitrouz's Avatar
Nitrouz
Back to Z
did mine myself. got the VT hood. took me about 20 minutes in total. Just needed to raise the front latch a bit and that's it.
Old Jun 29, 2005 | 09:38 PM
kopo's Avatar
kopo
Do you guys have any pics of your hoods?
Old Jun 30, 2005 | 03:49 AM
gringott's Avatar
gringott
See above your last post.
Old Jun 30, 2005 | 05:27 AM
kcobean's Avatar
kcobean
Here you go
Attached Thumbnails Seibon Hood - What is needed? How hard is fitting it?-myredz.jpg
Old Jun 30, 2005 | 05:33 AM
gringott's Avatar
gringott
kcobean:
Your hood and bumper look sweet together.
Great fit and paint.
Old Jun 30, 2005 | 05:34 AM
kcobean's Avatar
kcobean
Thanks!
Old Jun 30, 2005 | 06:04 AM
BrickydZ's Avatar
BrickydZ
Default To kcobean
How does the water effect the interior of the engine compartment?
Does the underside have paths for the water to run off or does it go straght down onto the engine, CAI etc?
thanks
Old Jun 30, 2005 | 06:45 AM
kcobean's Avatar
kcobean
thanks
The vents are completely open, so the water will run down onto whatever is beneath them. It's really not an issue though. You'd probably have to drive the car underwater to get enough water in the vents to mean anything. I just make it a point not to spray water directly into the vents when I'm washing the car.
Honestly, my car will probably never see much rain anyway, so it's a non-issue for me.
Old Jun 30, 2005 | 06:52 AM
mr2fasterthanyo's Avatar
mr2fasterthanyo
the water in the vents is fine...........
with the MR2's i had the rain shield removed so i could better air flow out of the engine, and never had a problem... and the were driven year round- rain/sleet/snow... and even in a torrential downpour, i never had a problem starting up the car, and once it is moving the air flows out of the vents (same with the seibon hood) so water won't run down there. But i would wash it normal, and yes the engine would get very wet, but as long as everything is tight in there, you won't get enough water in there to cause a problem. as stated above, to do any real damage you have to drive underwater more or less.
kcobean-- you car is just bada$$.... i just wish the foglights on that bumper were different, they make it look like a celica... (not flaming at all, just personal opinon)
Old Jun 30, 2005 | 07:08 AM
kcobean's Avatar
kcobean
Thanks.....The car is even better now with a big Turbonetics turbo sitting under the drivers side hood-vent. .
As for the fogs....You're not the first to say that.
Old Jun 30, 2005 | 02:04 PM
LaidbackRacr
Thanks for the info guys...I appreciate it. I spoke with Adam at Z-1 and he told me I needed to buy my own hardware. Needless to say, not a fan of that.
Old Jun 30, 2005 | 02:14 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
thanks for the info because i'm going to order ST next week. $600 shipped.
Old Jun 30, 2005 | 02:55 PM
kcobean's Avatar
kcobean
This sounds wrong to me. The hoood should ship with a couple of thin boards bolted to the mounting holes so that it can be safely stood up on it's edge without damage. Those 4 bolts are the ONLY hardware that you need to mount the hood. Even if it didn't come with them, you can buy them at your local hardware shop, so I wouldn't let this LITTLE detail discourage you from buying an awesome looking hood.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
