Removed rear wiper + covered hole *PICS*
The rear end looks alot cleaner with it removed and I never used it.
It was a simple process. The hardest part was twisting the rear wiper off and finding something to cover the hole with.
Took a trip to Ace hardware and found a plastic 1 inch hole cover. It is in the section with all the screw, nuts, and bolts if anyone is looking
They also have metal ones but I picked up the plastic one to paint daytona blue. I cut the tabs off the bottom and then superglued the cover over the hole. It fits perfectly.
Looks clean, they also have units to cover up the holes on ebay.
Originally Posted by GQ 350z
Do you ahve to take out the motor for this to work (i'm talking about the wiper's electric motor).
ravi
ravi
when I twisted my wiper off, the rotor post popped out and came off with the wiper.
becareful if this happens because it will fall out and may hit the body of the car and scratch it.
if it comes off with the wiper then you will not have to remove the wiper motor at all.
just pop the cap off the wiper, loosen the nut on the wiper, twist it off and done.
I took mine off too, rear wiper is pointless in AZ. Note guys do not tug on it when removing I scratch and dinged my hatch. I did the plug thing with silicon but it looked bad so I took my car in and had the hatch professionally done and removed my dings as well as two holes behind nissan emblem. I will post some nice pics over the weekend. Glad you like the mod to bro
Originally Posted by arlingtonz
do you have a link?
Originally Posted by rommel350z
