running lights help
i tried hooking up fog lights to the running lights today.. somehow i shorted something. tails, interior radio, running head light bulbs dont turn on.. i checked all the fuses and my connection(harness) i cant figure out what 2 do. any ideas?
k buddy u check the fuses that were infront of the batteri right also the ones under the panel on ur left foot. right.. but guess what u forgot to check the ones behind ur batterie. u need to take that cover right under ur wipers the long balck plastic. then u can't miss it it's right in there . hope this helps.
yup monos got the right fuse box.
and no doubt that was too much load to piggyback on that circuit. youll need a dedicated line operated either by its own switch or by a relay hooked up to the parking lights.
