JDM turn signals
Old Jul 17, 2005 | 05:02 PM
Landbarger's Avatar
Landbarger
Default JDM turn signals
Does anyone know the specifics on whether our wiring harnesses can run they JDM turn signals (ones under the Z on our front quarter panels) w/o modification? I'm sure it's been done several times, so can anyone shed some light on the difficulty of this procedure? I'd like to just have a dealership do it next time I'm in for a service, will they be able to understand it easily? Any tips? Thanks.
Old Jul 17, 2005 | 05:17 PM
GY-Z's Avatar
GY-Z
yes, its doable..
the Amuse Fenders come with a hole for the turn singnals, so i just put on a turn singnal and hook it up..
Old Jul 17, 2005 | 08:40 PM
ares's Avatar
ares
Veteran
without modification? whats that mean? of course you can go get a wiretap and hook it up. but if your asking if theres some wire lead sitting there waiting for you; probably not... how early you make the connection as in; right by the headlight; or back at the fuse box in the socket... thats up to you; I guess at the socket is the less modification route; but alot more work; youd have to find where that even is
Old Jul 18, 2005 | 03:54 PM
Landbarger's Avatar
Landbarger
Ok, right, there's certainly going to have to be the hole cut in the fender to put the light in, I was hoping though that the wires could be hooked up right to the fuse box or something, instead of having to put extra strain on your headlights/turn signals/etc. GY-Z - Did you wire it straight into the fuse box ("so i just put on a turn signal and hook it up.." Thanks for the response.
Old Jul 18, 2005 | 06:12 PM
ares's Avatar
ares
Veteran
Id be shocked if they didnt operate of the same circuit and fuse on the JDM cards. lots of stuff shares fuses; it doesnt hurt them. ussually anything that shares a line would share a fuse. but they would normally split it off at a harness where its nice and pretty, not just tapped in. you could do either. the harness is probably hidden somewhere near a fuse box though.
Old Jul 18, 2005 | 06:53 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Unless you're going to mount some serious light in there I really wouldn't worry about overloading the circuit. Most are capable (at your own risk) of twice the current draw. The turn signals are just a few watts each - 3 or 4 so I wouldn't worry at all.
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
May 30, 2017 03:28 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
