HIDs HELP
Old Jul 19, 2005 | 10:48 AM
Escobar's Avatar
Escobar
Exclamation HIDs HELP
I am trying to install a HID aftermarket light kit and was wondering if it is dependable, will it blow my fuses or melt the headlight? Also, do i have to drill the back of the headlight? Where are good places to mount the ballast and starter? I'd appreciate any info, thanks
Old Jul 19, 2005 | 10:53 AM
ryanhartnett's Avatar
ryanhartnett
I installed an aftermarket HID kit I bought from a member here and haven't had a problem with them.
I didn't have to do any drilling, though.
Old Jul 19, 2005 | 10:54 AM
Escobar's Avatar
Escobar
You didnt have to drill a hole in the cap that seals the light? There is no other way to get the wires in there
Old Jul 19, 2005 | 11:01 AM
GWAPITO69's Avatar
GWAPITO69
you have to drill a hole on the cap but that's about it as far as drilling. and no it will not melt your headlight or blow the fuses.. I have mine since last year and I never had any problem with it. after you install it make sure you adjust your headlight beam. there's a place at te bottom of the headlight assembly where you can place your ballast. do a search on this forum about it. There's a couple of threads that discusses this upgrade
Old Jul 19, 2005 | 11:05 AM
Escobar's Avatar
Escobar
thanks man, i'll give it a try
Old Jul 19, 2005 | 01:19 PM
ryanhartnett
the way I installed the kit you just kinked the wires b/w the cap on the back of light.
Old Jul 21, 2005 | 03:11 PM
Jun's Avatar
Jun
well, the reason escobar can't do that is because escobar is talking about an aftermarket kit (i suppose), while the one i sold you is an OEM kit, which is why your installation was a breeze
Pleask
Dec 21, 2021 03:17 PM
SirZaLot
Mar 4, 2003 12:34 PM
Daddy
Feb 4, 2003 11:13 AM
Mr Fairlady
Jan 28, 2003 06:08 PM
dvlad
Sep 15, 2002 07:48 PM
