Back-up lamp / reverse light NOT working! Please help...
Old Aug 8, 2005 | 04:57 PM
neur0sis's Avatar
neur0sis
Default Back-up lamp / reverse light NOT working! Please help...
Ok, so I noticed that my reverse lights on the back bumper are not lighting up when I put the car in reverse...
I swapped out the bulbs, and still nothing.
Is there a fuse for this, like the rest of the lamps? I found the "Rev Lamp" relay... could this cause the problem?
If anyone has info, please let me know!
Old Aug 8, 2005 | 05:46 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I'll assume you have a manual - the auto has a relay vice the switch.
From the ignition switch there is a 10A fuse (#71) under the hood - or as Nissan puts it "Intelligent Power Distribution Module Engine Room".
Note the auto-transmission relay location
See fuse #71 in the upper left-hand corner.
Yellow wire with red stripe.
There's a joint connector.
Back-up lamp switch on the transmission.
Orange wire.
A bunch of connectors - two lights.
Old Aug 8, 2005 | 08:20 PM
neur0sis's Avatar
neur0sis
So is fuse #71 for the SWITCH, or the lights themselves?
I hate getting into that panel, because its a huge pain in the azz. Nissan should have made this way more accessable.
I'll check the fuse, and see whats up. Thanks Paul!
Old Aug 8, 2005 | 08:29 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
It's for the relay (AT) and the lights. Copy these things to your local hard drive so I can break the links.
Old Aug 8, 2005 | 08:33 PM
Atwill's Avatar
Atwill
Hey, anyone have the similar thing for a 2003 Track Pack? I am having a similar problem, but it has to do with all the marker lights.
Old Aug 8, 2005 | 08:37 PM
neur0sis's Avatar
neur0sis
Paul -
I have the manual in PDF ... but I don't understand what I am looking for.
From the diagram, there is only one fuse (#71) , and I went out and checked the IPDM, and its labled "A/T Cont".
The fuse is fine.
Would this lead me to think the relay is shot? It seems to be the only other part of the equation.
Old Aug 8, 2005 | 08:38 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
It's probably going to be easier to get to the manual stick's switch rather than pull out that fuse panel.
In the manual transmission they just show a physical switch with just two pins which closes as the level hit's "R" I think. Shorting across that guy ought to bring the lights on too - you would see +12 VDC on pin #1 if the fuse was good.
Dang - just read the 6MT in your signature. Where you see relay just thing on/off switch with two pins.
Old Aug 8, 2005 | 08:40 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by neur0sis
Paul -
The fuse is fine.
I'm thinking something physical in the stick to swtich interface. Try pulling down a bit harder in reverse to see if the lights come up.
Old Aug 8, 2005 | 08:44 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Have a look at page 9 of the MT.pdf - the manual transmission for details on the position switch - it's on top of the tranny!
Old Aug 8, 2005 | 08:45 PM
neur0sis's Avatar
neur0sis
I can pull up the shifter trim piece and poke around in there. Do you know if the switch is UNDER the shift guide plate?
I'll look around in there, and see what I come up with.
(and you're right, its WAY easier to get in the shift switch area... but I have gone into the IDPM a few times before... so it only took a min. )
Old Aug 8, 2005 | 08:50 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
It's hard to tell. I have an auto (and two bad legs to go with it!) so I have never been there. From the pictures it looks like it's high on the driver's side, even with the boot area and may be 2-3" down. I'm just making WAG's here as the picture isn't that detailed and shows the switch in relation to the whole transmission stem to stern.
Old Aug 8, 2005 | 09:01 PM
neur0sis's Avatar
neur0sis
Ahh, cute.
Yeah, you really can't seem to get to that area from inside the cabin... I just took the whole assembly apart.
Looks like she might go to the dealer. At least its under warranty
Thanks again for all your help Paul. Hopefully they can figure it out!
Pleask
Dec 21, 2021 03:17 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
