Need some sanding tips for dash
Old Sep 21, 2005 | 01:01 PM
PumpedVA's Avatar
PumpedVA
Default Need some sanding tips for dash
Well I started my winter project today I dont know if some of you remember but I am painting part of my dash to match my fiber glass door panals. I will paint the part in the photo and carry that datona blue around the top of the dash were the defrost vents are, This way my blue door panals will wrap completly around my interior.
I am starting my sanding with 100 grip paper to get the texture off but didnt think it would be this hard. any tips would be great. part with texture is in photo parts by front window is sanding down easyer
Old Sep 21, 2005 | 02:13 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
What about a sand dremel that you can hook up to a power drill? They are circular so it should be easier to get into the crevices. Good luck on your project!
Old Sep 21, 2005 | 02:48 PM
disturbed2483's Avatar
disturbed2483
DO NOT DREMEL!!! the interior it takes alot of sanding and prep work to get those right your best bet is to remove them from the car and then sand and paint.
Old Sep 21, 2005 | 03:00 PM
B-Unit's Avatar
B-Unit
^^ +1
Old Sep 21, 2005 | 04:29 PM
PumpedVA's Avatar
PumpedVA
yea I have a spare dash so I will just swap them out when finnished
Old Sep 21, 2005 | 04:40 PM
schweatty's Avatar
schweatty
i am no expert by any means, but i would probably just mud it, and start the sanding from there. it would take maybe 3 or 4 skins, but trying to take that texture off, seems like massive *ss pain
Old Sep 21, 2005 | 04:45 PM
B-Unit's Avatar
B-Unit
start with 120 gritt to take off the texture, then 320 it. Youll be readon to paint then
Old Sep 21, 2005 | 09:59 PM
LaPuLaPu's Avatar
LaPuLaPu
I’d use synthetic bondo (filler) or resin + fiberglass, and then sand it for a smooth finish.
Old Sep 22, 2005 | 06:53 AM
PumpedVA's Avatar
PumpedVA
man this is alot of sanding. about half way done though
Old Sep 22, 2005 | 10:53 AM
Daewoo's Avatar
Daewoo
Get an orbital sander ($30-50 at homedepot). It helps make things go about 10 times faster. No need to go bondoing or glassing. That will only add more work. I sanded my enitire interior with a sander and it wasn't that bad.
I cannot even imagine the hell of doing it without the sander!
Old Sep 22, 2005 | 12:40 PM
PumpedVA's Avatar
PumpedVA
yea it sucks. today I got the top of the dash were the defrost vents are done and one side where the side vents are. Tomorrow I will finnish the other side and get it ready for paint.
Wonder how hard it will be to remove my dash?
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
