question on sealing headlight after painting
Old Oct 14, 2005 | 02:13 PM
kleenZ's Avatar
kleenZ
Default question on sealing headlight after painting
Watup, Ive painted my headlights and when I sealed the headlights back up, the right one was getting condensation on the inside. I took the headlight out and resealed with a helluva amount of silicone. I am pretty sure its sealed but when I sealed it, there was water still inside and there is still water in it a week and half later. Will it ever dry naturally or is it still leaking?? Thanks
Old Oct 14, 2005 | 02:24 PM
97ITR's Avatar
97ITR
After sealing the headlight, you should make sure there's no trapped moisture in it. I would just use a blow dryer to make sure the insides of the lights were all dry before re-installing the light bulbs.
Old Oct 14, 2005 | 02:35 PM
kleenZ's Avatar
kleenZ
I can tell you for a fact that there was trapped moisture inside.
Other than posing a threat to my HID bulb, will moisture hurt anything else. Also, if the headlight is sealed, is it possible that the moisture could still be in there for almost 2 weeks w/o drying up?
Old Oct 16, 2005 | 10:39 AM
97ITR's Avatar
97ITR
If you re-installed the HID bulbs before making sure any trapped moisture had evaporated than yes it would be trapped in there. When the headlight bulbs are installed, the headlight assembly is water tight so any moisture left in there stays in there. This is assuming that you resealed the headlights properly.
Old Oct 16, 2005 | 11:36 AM
ZZZealous007's Avatar
ZZZealous007
use a dessicant tied up in a peice of cloth. put in through the turn signal hole with a string attached. that might help clear up any excess moisture after a few days. Then reattach everything. If you still find moisture but up after you removed all the moisture with the dessicant then you know you light are not 100% sealed.
Old Oct 16, 2005 | 04:35 PM
plumpzz's Avatar
plumpzz
thats a real good idea.. use dehy-copper sulfate. leav it in there in a porous clothe lik cotton over an hour and itll work like a charm
Old Oct 16, 2005 | 05:45 PM
hndumafia's Avatar
hndumafia
kleen - id love to see your headlights in person. ive been thinking about doing this to my lights for a while, and after doing it to my friends wrx i'm not so worried about screwing up anymore. just want to see how it looks in person now.
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
Cashwin
Oct 1, 2015 06:36 AM
JGee450
Sep 30, 2015 04:32 AM
