Which bulbs do i need to buy?
Old Oct 25, 2005 | 04:14 PM
d!abolic's Avatar
d!abolic
Default Which bulbs do i need to buy?
I want to buy clear bulbs all around. I already got the side markers, so what does that leave? Please tell me the exact bulbs i need to buy and a place to buy them. I want clear bulbs that FLASH clear as well.
Old Oct 25, 2005 | 06:22 PM
d!abolic's Avatar
d!abolic
Helpz!
Old Oct 25, 2005 | 06:43 PM
ZlleH's Avatar
ZlleH
Well, I'm getting the PIAA Super LED Wedge Bulbs blue/white for my Day Running Lights. I'm waiting for it to come in the mail so I can install it.
Here is the site: http://www.piaa.com/LEDs/LEDs.html
The code is: PN 19262
I'm trying to see what other bulbs I can replace. I'm seeing what bulbs I can replace the turning lights with. I want LEDS all around.
Old Oct 25, 2005 | 06:51 PM
d!abolic's Avatar
d!abolic
Blue/white? How does that work? Wait a minute... do i need these to match my HID's? Because i'm gonna upgrade those to like 10000, so i'd need something REALLY blue. Also, what about all the amber bulbs?
Old Oct 25, 2005 | 07:40 PM
ZlleH's Avatar
ZlleH
It's exactly what it says, it will give you a blue/white light. basically, not totally white, and not totally blue. I picked it because it is my taste.
But you can buy the white/white one if you want. Depends on your taste. I like a little bit of blue, I think it makes the car sexy.
Old Oct 31, 2005 | 08:21 PM
d!abolic's Avatar
d!abolic
I need help guys. Are the PIAA white/blue a good choice for the daytime lights? What about the rest of em? What do i get for clear blinkers all around?
Old Nov 1, 2005 | 06:55 PM
d!abolic's Avatar
d!abolic
Guys, please help! I need to know what to buy for:
- daytime running lights
- high beams
- every single amber turn signal bulb
- any other bulbs that need changing?
Old Nov 2, 2005 | 07:47 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
- high beams
Next time instead of bumping your own thread, try searching the forums. This has been covered.
daytime running lights / trunk light / license plate lights - # 194
high beams - # H7
turn signal bulb / reverse bulb # 7440
map lights - # 3022
Some companies list different bulb numbers for the same type of bulb. No idea why, but sometimes you can find a bulb number guide that tells you which numbers's are equivalent. For example, like #194 = #168 or something. I forget.
You're on your own as far as vendors go. Eurolite is okay, polarg is okay, piaa is overpriced but okay. Do yourself a favor and don't touch the H7 bulbs with you hands, wear latex gloves or something. Also clean them with high purity rubbing alcohol and then use a computer-canned-air thingie to blow off any lint that stuck to the bulb.
Any regular bulbs that aren't HID or H7 you can touch.
Note, there are 3 kinds of 7440 bulbs. Two have a plastic bases, one has glass base. One of these two with plastic bases ****doesn't fit**** unless you shave off part of the base. You will KNOW if you have the one that doesn't fit. You can use a dremel, hot razor blade, sand paper, or just be creative. For more info, search the forums, this topic also has been covered.
Old Nov 2, 2005 | 06:43 PM
d!abolic's Avatar
d!abolic
Thanks for the codes! Now, where do i go to buy all these? And what can i do to make em match 12000k HID's? Can they be painted / sprayed / filmed?
Old Nov 15, 2005 | 02:41 PM
d!abolic's Avatar
d!abolic
Help, guys! Who sells clear blinkers?
Pleask
Dec 21, 2021 03:17 PM
Justin100
Nov 25, 2021 06:26 AM
Uriyo_
Sep 8, 2021 08:46 AM
Alexreyes
Sep 30, 2015 11:30 PM
