Painting brake calipers
Old Nov 21, 2005 | 07:01 AM
sp1kez's Avatar
sp1kez
Default Painting brake calipers
I'd like to match my calipers to the color of my car. Is there a paint I can buy at Home Depot, etc. rather than buying a bunch of the touch up pens and "writing" over the calipers? My car is Pikes Peak White QX1. I'm assuming that using spray paint is better than brush application?
Old Nov 21, 2005 | 07:20 AM
dirtroad's Avatar
dirtroad
Spray is the way to go. Make sure the paint you get can withstand at least 900 degrees, preferably 1200 degrees. Don't know if you'll find an exact match, but some sort of off-white should be available. Touch up paint will melt off, don't use them.
Old Nov 21, 2005 | 07:35 AM
Both spray and brush caliper paint will work. White brake calipers will stay clean for about 10 miles. Then they'll be filthy with brake dust.
Old Nov 21, 2005 | 07:44 AM
sp1kez's Avatar
sp1kez
Very good point davidv. My rims are black after just a few days of driving. Can anyone suggest a different color than white that will match nicely and won't be covered by brake dust in a matter of days?
Old Nov 21, 2005 | 08:00 AM
arlingtonz's Avatar
arlingtonz
i would just say don't do it...i think our small calipers look fine with a aluminum finish, anything else just draws attention where attention doesn't need to be drawn.
Old Nov 21, 2005 | 09:41 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
I have to paint mine, the back right's finish is coming off. :-/
Do you guys actually follow the directions on the caliper paint that says not to drive your car for 24 hours or do you just wait till it's dry?
Old Nov 21, 2005 | 09:45 AM
For suggestions take a look at the Pikes Peak White gallery of 350Zs.
Old Nov 21, 2005 | 09:48 AM
Real men don’t need no damn instructions!
Old Nov 21, 2005 | 10:00 AM
Fairlady_z33's Avatar
Fairlady_z33
hey just paint them red i think it always looks nice or go with gold, bronze i think they should look nice on the white Z
Old Nov 21, 2005 | 10:46 AM
sp1kez's Avatar
sp1kez
Great idea mc350z. How much different from the stock "metal" look is it? Do you have any pictures?
Old Nov 22, 2005 | 12:49 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
I would get the powdercoated if you are looking for a long term setup. I painted my calipers myself previously, and they just don't look nearly as good as the ones I got powdercoated. The paint seems to get duller every month on the DIY paint. I would recommend getting them powdercoated by mike here. He does a great job and has a core exchange so there isn't any downtime. His username here is 2003z. Good luck on your brakes!
Old Nov 22, 2005 | 02:45 PM
bmxox's Avatar
bmxox
Painted caliper never look good in my opinion, they look just that, painted. The finish isnt smooth, its always pitted. But they do make paint specifically for calipers, check the paint section at autozone or pepboys, brush on works the best, it lays out smooth and you dont see brush marks. Ive had to do a few for customers at work.
Old Nov 22, 2005 | 06:30 PM
andyisphat2004's Avatar
andyisphat2004
i got the paint at autozone. couldnt afford a big brake kit. cant see it to well in the pic due to lighting, but i didnt want anything that stood out too much anyways
Old Nov 23, 2005 | 05:34 AM
frankmusic's Avatar
frankmusic
Cool This is what I used
The G2 BRAKE Caliper PaintSystem Set adds a high-gloss color touch to your car's appearance, helping alloy wheels to better stand out, while adding protection by sealing the calipers from dangerous oils and chemicals.
The PaintSystem Sets are available in eight high-gloss, wear-resistant colors that can be selected to complement or contrast a vehicle’s primary and/or accent colors. Available colors include: Red, Yellow, Blue, Silver, Gold, Black, Purple, Green and White.
Old Nov 23, 2005 | 05:37 AM
frankmusic's Avatar
frankmusic
Cool I like the results
I used their Silver Gloss paint set. It leaves a nice and smooth gloss surface on your calipers.
Attached Thumbnails Painting brake calipers-frontcalp.jpg   Painting brake calipers-rearcalp.jpg
Old Nov 23, 2005 | 05:41 AM
frankmusic's Avatar
frankmusic
Cool Closer look
This is close up shot of the calipers before I mounted my silver NISMO LMGT-4 wheels.
Old Nov 23, 2005 | 06:41 AM
Santacruzslick
Veteran
How'd you get the nismo on there? Decal?
