Sequential Rear LED Turn Signal Retro
Old Mar 1, 2006 | 12:46 AM
  #81
Acree's Avatar
Acree
Originally Posted by NOBI
72c is pretty hot, thats like 176f. what temp does plastic melt warp or discolor?
Good question, and the honest answer is, I don't know. But I do know that the stars are far enough away from the housing to ever worry about heat or heat related issues. Also, how long will anyone EVER have the reverse light on for? 15 seconds, 30 seconds, 1 minute? The Z automatically shuts off the reverse lights after being on for 3 straight minutes I believe anyways. But, if it still needed, I can fabricate a heatsink for the luxeons for who ever thinks they need it. But honestly, I don't believe it's an issue.
Old Mar 12, 2006 | 01:05 PM
  #82
Dooly's Avatar
Dooly
I've got the basic sequence circuit board with LED made with using your diagram you posted, using SCR....
I'm not sure but SCR isn't functioning properly...
It's weird that some of the LED doesn't stay on, but some stays on...
Old Mar 12, 2006 | 01:53 PM
  #83
Dooly's Avatar
Dooly
It looks like this...
Click here to watch LED-Sequence-3
Old Mar 12, 2006 | 11:00 PM
  #84
Acree's Avatar
Acree
I watched the video and I had the same problem with some of the first boards I made and tried. I'll try to explain this as simple as possible.
The 4017, the component that is outputing the 9 segments, only puts out around 5~6mA per output. For a good majority of SCR's, this is not enough trigger current to make the SCR trip, and stay on, resulting in them coming on, but not locking. I found the perfect SCR that always triggers and latches, but unfortunately I don't have the link with me. I am home for spring break and I didn't bring my computer with my saved emails. As soon as I get home on Sunday, I will post up a link to the SCR's. Nice job on the circuit.
Old Mar 12, 2006 | 11:14 PM
  #85
Dooly's Avatar
Dooly
I saw your list of parts, is that the SCR you chose?
This is one I got..
https://www.jameco.com/webapp/wcs/st...oductId=119802
What is the use for 10uF?
Is the voltage regulator required? Car power source is not constant, but from 13v-14v they should run fine....
Sorry for all the questions..
Parts from Mouser
Quantity-------------Description------------Part Number
2--------------------555 Timer-------------512-LM555CN
2--------------------Decade Counter-------511-M74HC4017
36-------------------SCR------------------511-P0102DA
2--------------------Volatage Regulator----511-L4940V10
2--------------------1uF Capacitor---------80-C430C105M5U5TA
2--------------------10uF Capacitor--------80-T350G106K035AT
Old Mar 13, 2006 | 08:25 AM
  #86
streetd's Avatar
streetd
where is the diagram you posted?
Old Mar 13, 2006 | 12:05 PM
  #87
Acree's Avatar
Acree
This is one I got..
There is a new SCR that I picked up. I will post a link to it on Sunday when I get home. The 10uF cap is for another part of the circuit you need to add. Look under the 10 LED Sequential circuit at the next circuit. You need to incorporate the part that makes the counter always reset to output 0 when power is lost. And YES! The voltage regulator is required. If not, you will eventually fry the components and leds. If you keep on running the superflux leds at 13~14 volts for 4, you will eventually overdrive them, causing them to change color and burn out.
-Acree
Old Mar 13, 2006 | 12:46 PM
  #88
trescincuenta's Avatar
trescincuenta
What would be a rough estimate of the price of the signals if you include the reverse lights also?
Old Mar 13, 2006 | 01:34 PM
  #89
myspivey's Avatar
myspivey
Id be intrested in this GB as well. Also would be nice to get the price on the reverse in the listing. Looking forward to hearing more in May. Subscribed.
Old Mar 14, 2006 | 08:42 AM
  #90
Dooly's Avatar
Dooly
I didn't post it...
It's in this thread somewhere...
Old Mar 14, 2006 | 09:27 AM
  #91
usmanasif's Avatar
usmanasif
Andrew, just when I think you could not get more creative with LEDs...you do! Excellent work!
Old Mar 19, 2006 | 09:11 PM
  #92
Dooly's Avatar
Dooly
Any follow up??
I've been waiting for almost a week for you reply...
Old Mar 20, 2006 | 09:05 AM
  #93
Acree's Avatar
Acree
Any follow up??
FOUND IT! I just got home from Spring Break. Sorry about the delay dooly. Here's the link to the correct SCR's.
http://store.yahoo.com/webtronics/2n5064.html
To everyone else, prices and information will be posted on May 1st. That is when I plan on starting the group buy.
Old Mar 20, 2006 | 09:46 AM
  #94
NeptuneZ's Avatar
NeptuneZ
subscribed
Old Mar 20, 2006 | 11:53 AM
  #95
slackjaw's Avatar
slackjaw
Soooo cool. This has to be one of the most creative mods yet. I'll be down for the group buy.
Old Mar 20, 2006 | 12:07 PM
  #96
BOZ23's Avatar
BOZ23
me wants!!
Old Mar 20, 2006 | 12:34 PM
  #97
usmanasif's Avatar
usmanasif
Andrew, are you planning on offering non-sequential LED install as well? i.e. A simple blinking LED cluster.
Old Mar 20, 2006 | 12:47 PM
  #98
Acree's Avatar
Acree
Yup.
Old Mar 22, 2006 | 06:11 AM
  #99
sorphin's Avatar
sorphin
actually made a little board for myself... 21 5mm amber LEDs, and another board (for the reverse) w/ 21 18,000mcd 30deg white leds.. still not quite as bright as those Stars, but should be ok.. now the fun is going ot be getting the fixture open and not melting it/breaking it.. hehe.. yours look good, but i can't justify that much cash for lights
Old Mar 22, 2006 | 07:04 AM
  #100
Acree's Avatar
Acree
Nice. Congrats on trying your own project. Can't wait to see pics.
Just FYI - a tip on opening up the housings, I found it best to pre-heat the oven to 250 degrees, turn it off, then place the housing in the oven on top of wet cardboard. Let it sit for exactly 8 minutes. Pull the housing out, and it should come apart with a little pull. Good Luck.
