DIY crew: painting this car emblem?
Old Dec 3, 2005 | 12:16 PM
d!abolic's Avatar
d!abolic
Default DIY crew: painting this car emblem?
Here's the emblem i have for my car:
What i wanna do is paint the black red (to match my car) and paint the dark silver black. How do i do this?
For the red, to get a perfect match, i'd have to (i think?) use the factory touch-up paint for my car. But it can't be sprayed, so i'd have to brush it on? How do i do this without leaving brush-marks?
And how do i tape everything off, or whatever it is that i have to do in order to make this nice and neat? The red on black should be easy, but painting the thin silver lines black, once the red is already on may be tricky.
I also have to shave a few mm of plastic off the back of the badge to make sure it's flush to the surface of the car when i glue it on. Suggestions? I tried using sandpaper with somewhat mediocre results. I'll try another type.
Old Dec 3, 2005 | 12:19 PM
milkit's Avatar
milkit
id spray it all red, then tape it off with some good painter tape and an exacto knife, and then spray on the black over whats not taped
Old Dec 3, 2005 | 12:26 PM
d!abolic's Avatar
d!abolic
Where do i get red spray that perfectly matches Redline?
Old Dec 3, 2005 | 12:35 PM
RNL323's Avatar
RNL323
Mod My Ride
use carb cleaner to take off the black first...
my emblems are all silver... used carb cleaner and q-tips and it came right off.
Old Dec 3, 2005 | 12:38 PM
sluggoZ's Avatar
sluggoZ
ZPRESENCE is guy to see about a professional paint job...over at 350zmotoring! It's worth it!
Old Dec 3, 2005 | 12:39 PM
toretto26's Avatar
toretto26
u'll have to get the color code first
Old Dec 3, 2005 | 12:51 PM
d!abolic's Avatar
d!abolic
Old Dec 3, 2005 | 03:05 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
I usually order my paints from http://www.paintscratch.com/. They can match based on VIN number and you can get it in spray cans
Old Dec 4, 2005 | 12:18 PM
d!abolic's Avatar
d!abolic
Perfect! I'll get it from them then!
Old Jul 12, 2006 | 09:08 AM
DtyBlu350's Avatar
DtyBlu350
i painted my factory emblems black it turen out awesome
Old Jul 12, 2006 | 05:20 PM
illudezion's Avatar
illudezion
you should paint the black first then the red
Old Jul 13, 2006 | 11:06 AM
james840a's Avatar
james840a
Take the black off, mask the Z and outside trim ring (id used automotive masking tape) tack cloth it, then primer the metal, next you can use the touch up paint in a airbrush and spray it on, For the next step go to a automotive paint supplier and get a pint of du-pont or PPG clear coat and activator. They mix per instruction and airbrush the clear over the paint. Once dry take a exacto knife and cut around the areas that have the masking tape, then peel off the the tape.
Old Jul 13, 2006 | 11:14 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Old Jul 13, 2006 | 04:25 PM
cruznla9's Avatar
cruznla9
How long did it take you? do you have any close up pics?
JjL
East Canada
Jun 12, 2019 03:04 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Ronso
Oct 30, 2015 12:39 PM
NFAC
Sep 26, 2015 10:11 PM
Daniel_dh
Sep 7, 2015 12:56 PM
