Front headlight difusser removal
Old Dec 4, 2005 | 01:57 PM
ZlleH's Avatar
ZlleH
Default Front headlight difusser removal
I was thinking of getting Rick's clear difusser to replace the ornage difusser in the headlight cubby. But I read his instructions on taking the headlight apart and it mentioned putting the headlight unit in the Oven on back @ 225 for 12 minutes
Is this really necessay to take apart the headunit? Has anyone done this mod and had to do this oven baking thing!?
Old Dec 4, 2005 | 02:20 PM
tuner4life's Avatar
tuner4life
yea i have done the mod and yes u do have to put it in the oven here was the final turn out of the mod......i also sprayed the plastic pieces with a flat black spray paint
Old Dec 4, 2005 | 07:47 PM
ZlleH's Avatar
ZlleH
Damn, I was hoping I read wrong.
So what part of the headlight unit did you put on the baking sheet? the glass part or the plastic part?
Why is this oven baking thing neccessary? is it to make the plastic softer so the glass can be taken out?
Do you have to heat it again to put the glass back after you are done?
Wouldn't the heat melt the plastic or anything else?
Did you run into any complications while doing this mod?
Sorry for all the questions.
Old Dec 4, 2005 | 09:12 PM
JamRWS6's Avatar
JamRWS6
Most of the time it is so the cement/adhesive holding the sealed headlight together becomes gooey and lets you separate the pieces to work inside the headlight. Hope that helps.
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
07ZEKE
Aug 23, 2021 09:15 PM
